budget throttle response?
what are some ways to gain better throttle response?
if this helps any, i just ordered a magnaflow muffler, airraid throttle body spacer, and a k&n cold air intake for my runner. I am told i will gain some power from this combo but i also want a gain in throttle response... any input is appreciated.
Throttle body and MAF:
http://www.4runners.org/writeups/throttle/index.html
If you're taking the TB off to get at the IAC, just clean the TB while it's off, as you'll get a better job done.
https://www.yotatech.com/forums/f123...ac-pics-92286/
and yes cleaning the TB will help a lot.
But as some one said earlier a header is the next option and if you want more after that then the supercharger is better than the turbo set ups but the turbo is cheaper~
that parts list doesn't sounds like budget to me. return that throttle body spacer. it really doesn't do anything. do the TRD O gasket mod instead
https://www.yotatech.com/forums/f2/t...gasket-166753/
Second that. I've heard from many people the TB Spacer does nothing (maybe make a little whistle noise or something like that).
I have a K&N Kit on mine. It helped a little bit, not enough on our engines for the money. It's always a sore topic on here for some reason. I personally like K&N and never had any negitive results from them. Others would rather eat their young then to put one on. Save and get a snorkle maybe.
I've heard good things with the TRD O Gasket and I plan on doing it myself someday.
Something no one has listed yet is check the cables on your TB. Tighten them (they stretch \ loosen over the years)
There is also a thread on here stating the "Deckplate Mod" doesn't do anything either. He had some great science backing his statements. I've never done it so I have no opinion on it.
Combine the elbow & ISR mods
with the muffler. I did the ISR, elbow mods and installed a dynomax super turbo muffler. Once i reset the EFI fuse and started using 89 octane fuel the throttle response and pull is improved a lot. yeah me
