Broken Rear lug nut stud. Difficult repair?
In all the years I have never pressed a stud in the axle.
I have also changed quite a few studs broke by idiots .
I cut the stud flush off with a cut off wheel, center punch the stud I have a special made tool for the air hammer pops the broke stud out .
to install i use a lug nut of the correct thread pitch put on with the flat side toward the axle 1/2" impact draw it right in .
No drama no bearings no big $$$$$$ repair bills
This is like changing front brake pads by removing the whole caliper taking it to a press to push the piston in and remove the pads .
i have seen this done just shake my head and walk away
#25
We are off topic but you don't need to remove the caliper off and put it into a press to retract the piston. While on the vehicle use the old brake pad and a c clamp to push it back in. If you have both off then you may have to clamp the other side to keep it from pushing further out.
#26
From: Where it always works if you work it, in Sunny Selinsgrove, PA
the1998sr5
15
07-14-2020 09:35 PM
