Brake System Warning Light
Old 11-28-2005 | 01:24 PM
Darx's Avatar
My brake system warning light staying on after the emergency brake has been released. I checked the fluid and it's topped off. What other possibilities are there? Brake pads?
Old 11-28-2005 | 01:26 PM
Localmotion's Avatar
the wheel sensor might be dirty? Try spraying down there with a lot of water. My sisters accord does the same thing...not worried though b/.cwe know its not up
Old 11-28-2005 | 05:28 PM
tc's Avatar
tc
Mine came on for a frozen caliper. Sometimes it would go out after hitting a bump, tehn come back on when you hit another. (Interestingly, that will cancel the cruise control)
Slide the caliper off and make sure all the pistons move the same amount when you have someone step on the brakes.
Old 11-29-2005 | 01:51 PM
Darx's Avatar
The problem is with the driver's side fron caliper. It's leaking brake fluid pretty good. I think it's the calssic banjo nut problem with the Donahoes. At full turn I look and it's not hitting but I do't have anyone to hold it at full lock to see how close it's really getting.
ashersullivan88yota
01-18-2022 06:37 PM
BeMiceElf
10-10-2015 10:40 PM
09-04-2015 10:27 AM
Johntom240
7
07-13-2015 01:18 AM
Huntingtruckcletus
07-08-2015 06:26 PM
