Brake ??'s
Brake ??'s
my pedal all of a sudden a couple weeks ago became quite a bit less "responsive" . i used to be able to touch the pedal and they would GRAB hard everyone always complaiuned when they drove it . My truck is a 01 tacoma x-cab v-6 auto prerunner it has 45 k miles on it . it had the prop valve warranty replaced at emm 20k i think and was fine . tonight i did some research and i read all the brake post i could find . no leaks visible , is my booster or M/C going bad?
in the posts i read about the junk rotors ,GADZOOKS they were fine until i turned them tonight ahahaha :pat: . oh well new ones tommorrow . i have morse brand ceramic pads . well sorry for the long winded post , and the the rear shoes are worn on the bottom moslty too . -Andy
Originally Posted by jimabena74
sounds liek rear shoes need to be replaced... you turned the rotors tonight and now there is no pedal pressure? sounds like you introduced air into the system when you took the rotors off
1uzRunner
63
11-10-2018 04:58 PM
