Brake pull fixed!
Old 10-28-2005 | 07:15 PM
NathanBERG's Avatar
Lightbulb Brake pull fixed!
I have had a problem with my brakes pulling to the right. I replaced both front calipers and pads and bleed and flushed the system. still pulled.
I replaced both tie rods, idler arm and had the Recall done on the relay. I also checked to make sure the bearings were good and they were. The Runner would track just fine driving down the road until I hit the brakes and then HOLY SH%!
I was ready to just stick a gas soaked rag in the fuel tank and then I discovered the problem. :pat: The four bolts that hold the Master cylinder to the brake booster where very loose! I tightened them all up and BAM! a test drive revealed that indeed it was fixed! I slam on the brakes no hands on the wheel and straight she go's! I am very happy to say the least ! I have had to put up with this thing for far to long!
I just wanted to share this with the yota community incase there are any doe does like me out there.
Old 10-29-2005 | 09:07 AM
brandontrek's Avatar
wow...that might be the cure to my problem...only mine doesn't sound as bad as yours...mine is just after the brakes get hot...then she pulls to the right with a vengance....
Eggslinger
06-08-2019 04:32 PM
jasonty
41
12-23-2018 02:00 PM
09-04-2015 10:27 AM
Jnkml
07-06-2015 02:20 PM
ptb12
07-05-2015 02:49 PM
