Brake Issue
Brake Issue
if i brake kinda hard, my brake pedal goes down about 75% and gets firm, then it kicks back up about 15-25% and brakes harder. no matter what, the brakes dont work like they should. it feels like the brakes finally "wake up" or something.
also, my rotors are warped. how hard is it to replace those? do i have to repack the bearings?
thanks
thanks
you need to repack or replace the bearings and the grease seal if you are planning on replacing your rotors... not too sure on exactly waht it sounds like is happening, but it somewhat sounds like abs
ive thought about getting them machined, but they've been warped for so long i doubt they're still machinable. plus those brembo rotors are sexy
anybody know about what my problem sounds like?
My brakes have been doing that too, lately. Seems to do it more in hot weather. I have no idea what it is, but I figured it had to do with the MC. It seems fine so far...let me know if your brakes go out and you hit somebody...I'll change mine then...
If your 2wd hub is the same as my 4wd, you'll need the huge 54mm socket.
Are you back from the desert?
yup
hmm... im still curious about this brake problem. im getting new shoes by the way, 31x10.5r15 bf goodrich all terrain T/A KO. 113.27 + tax + 11.75/tire for install. 535.19 out the door
jasonty
41
12-23-2018 01:00 PM
CanRunner
07-20-2015 01:29 PM
Johntom240
7
07-13-2015 12:18 AM
