Body Lifts
Body Lifts
Hi I am interested in buying a body lift for my truck. What company(s) make good body lifts. Are they hard to install? And are the gaps easy to cover up? Any other information is appreciated!! Thanks
Originally Posted by r0cky
thanks... so basically roger brown bl's are custom made for your truck?
i think so, yes. unfortunately, i don't know too much about them, but i know a ton of people are running them ... if you do a search for "roger brown" here you'll find tons of threads about the lifts. they're supposedly very easy to install - much more so than a suspension lift. sooo ... but they're the most popular body lift you'll see around here. (if not the only) sorry that i can't help much more than that ... ! hopefully someone else more knowledgeable will chime in.
Originally Posted by AZ4ME
I got a 1" RB body lift on mine and it is top quality stuff. A lot easier to install than I anticipated.
Great thanks. I think thats the route I will go!
Originally Posted by Swede
I've got stuff from him and he's allways been very helpful with any questions and prompt with his service.
Yeah I emailed him last night and 10 minutes later he responed to my question. So do I just need the blocks? What else will I need!! He said a 1" bl will be able to clear 33x12.50 is that true for mud terrains too?? Thanks
As I describe on the page, you need the blocks to get the lift (that's what holds the body off the frame), then you need some longer bolts to keep the body in place, supply your own or I can supply them. Then, you may need various brackets, etc. to raise/lower other parts if desired (bumper, radiator, etc.). I describe the issues in clearing 33s, lots of variables, wheel width and offset/backspacing, width and actual height of the tires (both can vary by mfg. and even tread style). I list a "recipe" for fitting 33x12.50 BFG Mud Terrain tires on an IFS pickup including specific wheel specs., etc. Read that section and the links to further information I provide there. A 2" lift would make the tire fitting easier, esspecially if you want a wider wheel or more offset or are averse to doing any trimming, etc.
For instance, I see you list 15x8 Black Rockcrawler wheels. If those are the common 3.5" backspacing, they will be sticking out 1.25" wider (per side) than the 4.75" backsapced wheels I list on my page, so a 33x12.50 probably will require a 2" lift to clear or extensive fender trimming/seam hammering. Why? Look at the way the front wheels move when they steer. The steering pivot point is fixed. The arc swept by the tire is determined by how far away the outer edge of the tire is from the steering pivot point. Wider wheel, wider tire or more offset wheel will swing a wider arc. The fender is fixed in space, if the arc of the tire meets the fender, you have problems. The body lift raises the fender, to try and mitigate the interference, usually by raising the bottom of the fender up above the centerline of the tire, As you can see below, if the body were raised an inch or two, the center line of the tire (where it is the largest) would fall below the lower lip of the wheel well and rubbing would be lessened:
Body Lift Kit Pricing Info:
http://<a href="http://www.4crawler....ricing.txt</a>
Notes:
If you have trouble with the columns not lining up, be sure to select a
"mono-spaced" font for your e-mail reader, such as "Courier"
See above referenced file for description of the kit letters
Kits B/D/F/H are mutually exclusive, that is kits F and H include kit D/B
(*) Optional at that height
(**) Zip code/country needed for shipping and sales tax calculation
(***) Requires drilling, 2"+ flip stock bumper brackets & redrill holes
Front bumper bracket on 2000+ 4Runner/2001+ Tacoma, will need to remove
or raise the inner bumper for the outer bumper to clear when lifted
(***) For linkage style early Toyota transfer case shifters, if your t-case shifter
is direct, this is not needed nor will it even fit.
Drop me an e-mail if you need any more information and send me your zip code and I can get you a total w/ shipping.
Code:
1979-1988 Pickup/Hilux Body Lift Kits: Kit: Cost/1" Cost/2" Cost/3" ------------------------------------------ B $ 60.00 $ 76.00 $ 92.00 (Ult. blocks only) D $ 85.00 $101.00 $117.00 (Kit B + h/w only) F $ 95.00 $111.00 $127.00 (Kit D + front bumper or radiator) H $105.00* $121.00 $137.00 (Kit D + front bumper + radiator) BS $ 8.00 $ 10.00 $ 12.00 (Per pair of bed spacers, 1 or 2 pr.) AT n/a $ 40.00 $ 50.00 (Extension for A/T shifter ****) SE n/a $ 30.00 $ 30.00 (For 1-piece steering shafts) P $ 55.00 $ 55.00 $ 55.00 (Poly body mount bushings) CLR $ 14.00 $ 14.00 $ 14.00 (Custom color lift blocks) HD $ 15.00 $ 15.00 $ 15.00 (Upgrade cab hardware to Grade8) SL n/a $ 15.00 $ 20.00 (screw-on Shift Lever extension) ------------------------------------------- Typical Kit $ 95.00 $121.00 $137.00 + shipping** (F) (H) (H) (Typical kit contents)
In case 4th gen owners didn't see, there is a RB body lift for us. Does any 4th gen owner think that may help with some of the rubbing issues some (those with spacer lifts) were having with the larger tires?
Herman
Herman
Originally Posted by castrolSi
So let me ask you...
If I am running an electric fan mounted to the radiator itself, do I need
to move the radiator at all?
~castrol
~castrol
And this is precisely why I don't have a "pre-packaged" all in one kit, since almost eveyone needs something different. You order what you need.
