Body Lift Removal
Old 08-17-2009 | 12:17 PM
GLittler's Avatar
Body Lift Removal
Hi Guys,
I just bought a 4runner (A Black 1999 Highlander) and it has a 2.5 inch body lift which I don't like the looks of and in combination with the 3 inch suspension lift its all a bit too much so I want to remove the body lift. What I don't know is what I need to remove the lift (ie spacers and other things). Any links you can provide will be very helpful.
I'll post pics of it later once it gets back from Discount Tire
Old 08-17-2009 | 12:25 PM
4Crawler's Avatar
See below:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ11
and kit D, 0" for the stock length hardware:
- http://www.4crawler.com/4x4/ForSale/...shtml#GenIII.2
Old 08-17-2009 | 12:31 PM
bgmac's Avatar
Make sure you dont forget to post the pics!!
Old 08-17-2009 | 12:44 PM
GLittler's Avatar
So do I just need the D kit or the D+P?
Old 08-17-2009 | 12:55 PM
4Crawler's Avatar
Kit D is the stock length hardware, if you want to simply remove the lift and re-use the stock body mount bushings, then kit D is what you need. If you want to replace the stock (rubber) body mount bushings, for example if the existing bushings are damaged, then order kit D+P.
Flying91
45
04-11-2024 05:39 PM
09-04-2015 10:27 AM
coffey50
07-28-2015 11:55 AM
Backcountry411
07-24-2015 09:06 AM
MTLroadierunner
07-06-2015 01:17 PM
