body lift install
Old 06-09-2005 | 04:32 PM
body lift install
For those of you souls that have done a body lift on a 1st gen runner, is there a step by step instructions that also talk about problems I might run into?
Also an idea of what else I might need besides the lift kit. I am wanting to get everyting at once before I start.
Also, I found a good deal on a 3" lift, but that is more than I am wantin from a body lift, 2" max is what I want. Can I just cut off an inch from the parts and use it?
Thanks
Kent
Old 06-09-2005 | 04:35 PM
r0cky's Avatar
have you checked out Roger Brown's body lifts? his company is 4Crawler:
http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
lots of us are using his body lifts.
Old 06-09-2005 | 05:01 PM
No, I have not, thanks for the link.
Old 06-09-2005 | 05:05 PM
r0cky's Avatar
sure thing! i'd recommend his body lift kit over pretty much any of the other ones out there, partly because he is so helpful and his reputation is golden. good luck!
Old 06-09-2005 | 05:07 PM
waskillywabbit's Avatar
I got an 85 4Runner and I've done a body lift. Nothing to it. Email/PM w/ any questions and check out Roger's site for sure.
Old 06-09-2005 | 05:29 PM
jimbo74's Avatar
i have done a bodylift on my pickup 3" roger site is what i used for my instructions...i actually got a PA lift and its instructions sucked.... roger and i designed a custom steering extension for my truck
Old 06-11-2005 | 08:10 AM
I am going to give RB a call. at least I will know what all I need and be able to get it there.
THanks
Kent
Old 06-11-2005 | 08:20 AM
BajaRunner's Avatar
Another vote for Roger/4Crawler!
Old 06-11-2005 | 07:08 PM
Albin's Avatar
I did a 1" BL with Roger's kit. Instructions were clear and easy to do. I had an issue with my auto shift lever that I fixed with a 2" piece of 1/4" x 1" strap.
Roger's kits are the shiznet, don't even consider getting them from someone else.
BTW: by the body mounts while you're in there, easy to install while doing it.
I got my 7/16" x 4 1/2" Grade 8 bolts from McMaster, I think you can get them Roger also. Make sure to tell him what size bolts you're going to use so he can drill out the pucks before he sends them.
Al
Old 07-07-2005 | 06:52 PM
How much did the lift, plus all of the extras cost you guys. Using Roger's kit of course.
Thanks
Old 07-07-2005 | 07:06 PM
2" body lift on my 00 w/ HD hardware and shifter extension...less than $200
1" body lift on my 85 w/ HD hardware and all new body mount bushings...less than $225 (if your body mount bushings have never been replaced and you do a body lift, replace the bushings too)
Flying91
45
04-11-2024 05:39 PM
icentropy
09-16-2020 03:47 PM
09-04-2015 10:27 AM
skoti89
07-06-2015 08:45 PM
MTLroadierunner
07-06-2015 01:17 PM
