Blew My Motor Last Night - Replacement Q's?
Well, 15lbs of boost and a good tune seemed to be too much for the stock internals to take. Broke a rod last night and now need a good replacement. I found a low mileage motor from a 2002 close by for a decent price. This should fit in my 99 right? I know the throttle by wire is used but I plan on just re-using my current TB on the new motor. Is there anything else I need to consider?
Thanks!
Thanks!
Thanks!
Thanks!
They should all work fine but a little homework to verify the part numbers at the dealer would probably go a long way towards saving you any potential headache later. The throttle body is the only glaring difference that I can think of offhand between the 99 and 02 engines but that doesn't mean I'm not missing something.
I am looking into a forged bottom end, but it is costly and I won't be able to take full advantage of it unless I go with a standalone fuel managment which is another big money and time item.. The cylinder can hold plenty - 800 hp on a stock block from psi racing..
The last dyno I got with my old turbo was 272hp and 330 ish TQ at 7 lbs of boost. Since then, I got an upgraded turbo and turned up the boost to 15 lbs. Was planning on going to the dyno in two weeks but it looks like I will have to wait now...
I won't know untill I pull it apart, but this motor has been boosted almost all it's life - most of it with the S/C and no fuel mods - so it isn't a huge shock to me that this happened.
06-01-2021 02:51 PM
MMA_Alex
25
04-18-2017 06:07 AM
