Bilsteins or OME's for daily driving and occasional towing.
Old 01-20-2004 | 11:04 AM
goldtaco9's Avatar
I know this is a subjective question but I am looking for the best combination to suit my specific needs for my 2000 4Runner. I just bought this 4Runner with 74K on it and the shocks are pretty much shot.
I have been reading as much as I can find about shocks on this board and almost pulled the trigger on a set of Bilsteins before I started to worry about a harsh ride.
I want a comfortable ride for my daily commute and yet I need to be able to tow a racecar and trailer (3000 lbs.) on weekends. I will also be using the 4Runner for camping but I do not need anything too aggressive for off-roading.
I would not mind a very small lift of an inch or so but it is not really necessary.
I was thinking that the “medium” OME and then a set of airbags in the rear with onboard air for use when towing.
I will also be adding an ARB for its deer deflection capabilities.
All opinions welcome.
Thanks,
Mike
Old 01-21-2004 | 01:08 AM
Los Gatos?'s Avatar
I have bilsteins and LOVE the ride. Not too harsh at all! I have never towed with my 4Runner, but for daily driving they get two thumbs up.
Old 01-21-2004 | 07:56 AM
X-AWDriver's Avatar
I hope to have my Bils on soon and I'll compare the ride to my mom's low mileage '99 Limited on stock suspension.
Old 01-21-2004 | 09:31 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I have Bilsteins on my otherwise-stock 2000 SR5 and I consider the ride quite stiff when unloaded, although I prefer it to the mushy ride from the stock shocks. The handling improved dramatically. I tow campers and boats and the Bilstein's are excellent when loaded.
If you drive mostly well maintained roads you shouldn't notice it. I drive a lot of secondary and tertiary roads in PA which are in poor condition and I prefer the handling over the comfy ride.
Old 01-21-2004 | 09:54 AM
jacksonpt's Avatar
Senior Member
I have OME HD. I got it because I tow a lot in the summer (boat). The setup holds up great to towing, but when not towing the ride is pretty stiff. I run my tires at 20psi to make up for it and the ride is much improved. I think the OME light duty gear with airbags would be a good setup.
Old 01-21-2004 | 10:19 AM
mochoajr's Avatar
Bilsteins
The Bilsteins are stiffer, but a better ride overall.
mochoajr
Old 01-21-2004 | 12:58 PM
GoudyMan's Avatar
bilsteins!
Old 01-21-2004 | 01:06 PM
waskillywabbit's Avatar
OME
I have the OME stuff all around too, 891s and N86s in the back with 881s and N91Ss in the front. I really like the ride and the feel. It definitely doesn't ride like a sports car, but it is as smooth or smoother than the trucks I've owned. I like my OME!
Sleaker
08-26-2020 07:03 AM
mskalmus
05-28-2017 08:51 AM
Road Bull
10-10-2015 05:55 PM
09-04-2015 10:27 AM
Coreyr384
07-10-2015 12:13 PM
