Bilstein struts.........Help me!!!!!
Hello everyone!!!! this is my first post for yotatech forum. it has been a very informative forum and i'm loving it!!! anyway, for those suspension expert here i hope you could help me.
I owned a 1998 Toyota Landcruiser Prado or 95 series. I've learned that it has the same suspension configuration with the 1997-2002 4runner in the US. I am currently using Bilstein shocks and struts with OEM toyota spring. in 2 months time i will be installing an arb deluxe bar it will surely drop the front so what is the best option to do without changing the Bilstein? do i have to install a spacer or change the spring? (what spring should i use) i dont do off roading just dont want the front end look sag.
Thanks for helping.....
You're springs will have a higher weight rating, due to the fact the LC is a much heavier vehicle.
Your best bet is to check out and call http://www.sleeoffroad.com/ as they are the landcruiser specialists.
The easiest thing would be to add a spacer up front. But, I had no idea that they had the same front end components as the 4runner.
Help Me Help Me Help Me!!!!!!!!!!!!!!!!!!!!!!!!!!!!111
"Bilstein struts.........Help me!!!!!"
HELP ME, HELP ME!!! MY LIFE IS OVER IF I DON"T GET THE RIGHT SUSPENSION!!!! OH NO!!!!
MY BALLS ARE KEPT IN MY GIRLFRIENDS PURSE......
I'M JUST A POOR NEWBEE WITHOUT A CLUE!
Seroiusly, i'm just messin!
actually I'm the newbee,
and I'm just messing around...... really
Last edited by icerunner; 04-07-2007 at 02:47 PM. Reason: Bilstein struts.........Help me!!!!!
yeah either ban or just know you're pretty wierd
JookUpVandetti
09-30-2015 08:58 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
