Bilstein 5100 Coil-overs
Old 08-22-2004 | 02:06 PM
Ritchie's Avatar
Does anyone have info on this product?
Check out this link. http://shop.offroadwarehouse.com/ind...53&item=218930
This might be a dumb question, but can these be 'McGyvered' to fit a Tacoma?
Just a thought, the price is great and the manufacturer is proven.
Any ideas and input would be cool.
Old 08-22-2004 | 03:10 PM
desert whomper's Avatar
they wont fit tacomas, if u want a coil over for tacomas get the sway away ones
Old 08-22-2004 | 03:59 PM
User 051420's Avatar
Assuming the problems is with the top plate, that could be easily changed for something that WILL work. I know I ordered Tundra SAW's for my runner and they're supposed to fit. I guess the question is: How good are these coilovers?
Old 08-22-2004 | 04:07 PM
Ritchie's Avatar
So Gapguy,
You are saying that they will work with a little 'McGyvering'?
The Bilsteins I have are 3 months old and have performed flawlessly.
I will be going with 33 x 12.50 x 15's soon and will need the extra height to delete any rubbing issuses.
Your thoughts....
Thanks for the input.
Old 08-22-2004 | 04:14 PM
So you have no lift at all right now? The reason they would't fit out of the box is that the mounting holes in the top plate are different between the Tundra vs. Taco/Runner. SAW's come drilled for both. It's my assumption that you could drill in the correct hole pattern (3 bolts), and make it work properly. My other question for you: Have you looked at SAW's? Or possibly even better, Steve Scheafer's "FrankenStrut"? Try checking out THIS Thread. I'm actually considering it myself, we'll see how the Tundra SAW's work for me.
ZGjethro
06-08-2017 12:04 AM
Scottcrb
03-03-2016 12:57 PM
JookUpVandetti
09-30-2015 09:58 AM
toyotasaurus
09-24-2015 04:30 PM
JookUpVandetti
09-17-2015 10:25 PM
