Big Tundra brakes on 3rd Gen 4runner
#81
i would just do the 199's. 231's are just that much wider, and would have more chances of rubbing on the wheels. the 199's i put on my runner made a HUGE difference - so much so that i don't know if it would be all that noticeable to go to the 231's. also, even the 199's rubbed on my LX450 wheels.
#82
#83
Originally Posted by ebelen1
I would agree w/ Andy. Also, just b/c you have 17" wheels doesn't mean you won't want to sell them separately if you ever got rid of your truck. I like the option of knowing I can put on any standard 16" OEM wheels and they'll fit. Just food for thought...
#85
That's exactly what I was trying to say. Awesome! These last 4/5 posts should clear up any other questions people have regarding 199mm vs. 231mm via opinions.
Also, to all the people who are trying to find solutions to different models, I suggest starting a new thread and motioning to this one to avoid confusion.
Thanks
#87
Need brakes bad! Waiting on a set of MT Classics in 16x8 with 3 5/8 BS, anyone know if the 231's will clear the wheel w/o grinding? Would like to go junkyard shopping this weekend and have it all layed out when the rims arrive.
Thanks!
Thanks!
#89
On another note, dont the Tundra calipers have larger pistons then the 4Runner calipers?
#90
#91
the pistons are the same exact diameter. i didn't mic them, but i did measure them. they are the same diameter. however, the pads have more surface area for contact with the rotor and the rotors are thicker (also a wider caliper casting to fit the wider rotor) to prevent warpage that 3rd gen's see.
#92
Did you weigh the two rotors as well? I am curious on the weight differences.
#94
Im looking to go with the 231 mm Tundra calipers with Brembo Rotors.
Will these fit my 2000 SR5 4Runner????
http://cgi.ebay.com/ebaymotors/ws/eB...2065895&rd=1,1
Please let me know,
thxs,
maguirre
00' SR5, 5spd
Please let me know,
thxs,
maguirre
00' SR5, 5spd
#96
Please let me know,
thxs,
maguirre
00' SR5, 5spd
Please let me know,
thxs,
maguirre
00' SR5, 5spd
The drilled and sloted rotors look cool but they really aren't going to add much except cost (actually if you heat them up too much, often the cross drilling can cause the rotors to crack). My preference would be to just use the standard unmodified Brembo blanks.
#97
I just bought these
http://cgi.ebay.com/ebaymotors/TOYOT...spagenameZWDVW
and the ceramic pads. plan to do the upgrade this weekend. I'll let you guys know on the quality.
#99
Please let me know,
thxs,
maguirre
00' SR5, 5spd
Please let me know,
thxs,
maguirre
00' SR5, 5spd
I just found out that these are fake Brembos. Brembo does not make drilled/slotted rotors.
Oh well... there goes that....
maguirre
00' SR5, 5spd
#100
Now just go to www.tirerack.com and order yourself a set of the real deal.
