Big Tundra brakes on 3rd Gen 4runner
Old 01-25-2006 | 07:34 AM
  #41
MTL_4runner's Avatar
Originally Posted by FilthyRich
I just places a WTB ad a tundrsolutins.
I would love upgraded brakes, but for some reason I am over thinking this mod--damn varying p/ns....
I am pretty sure the S13WE is the part people with 4runners want to find (which is also the part the Tundra TSB fix removes). People could also check with Toyota dealers who are removing these for Tundra customers doing the TSB fix.
Old 01-25-2006 | 07:49 AM
  #42
ebelen1's Avatar
Jamie,
I was looking on the wrong side but I'm at work in some dress clothes so getting under the truck is a no-go. This will have to wait until the weekend when I can climb under there w/ sufficient light.
I will do this for you but just be a little patient.
Edwin
Old 01-25-2006 | 08:08 AM
  #43
Originally Posted by ebelen1
Jamie,
Edwin
No worries Edwin, it can wait.....didn't mean to rush you....I didn't expect you to roll under the truck in a suit.
Your input would be most helpful to everyone.
Old 01-25-2006 | 08:10 PM
  #44
Fingers's Avatar
Gents, I checked the calipers and they are 13WL castings. Makes sense cuz they are the larger TSB calipers. Me thinks this one is beat to death.
Old 01-26-2006 | 05:24 AM
  #45
Yep, if anyone ever has any questions on what to do we want to be able to just point to this thread.
Thanks for checking yours for us!
Old 01-29-2006 | 10:23 AM
  #46
ebelen1's Avatar
Jamie, it's not in the same exact spot as your pic but the rear caliper says "SI13WL." Hope this helps.
This is really confusing as now I'm not sure which calipers I really have. I did not need to do any shaving like Fingers yet from the description above, I seem to have the same calipers. My mechanic didn't even need to cut off part of the heat shield, just bend it so the pads sits on the rotor properly. I know this has been beat to death but I don't know how to make this less confusing.
Old 01-29-2006 | 06:44 PM
  #47
Hehehe.....this isn't getting any simpler.
There are only 2 casting numbers for either Tundras or Sequoias (S13WE or 13WL) and I searched extensively for any others and have yet to find any. I am not sure how to interpret the casting number you have, the only way to tell now would be to remove the wheel and look at the pads (I don't expect you to do this) and measure the length of the brake pad metal backer (to see if it is 4.7" or 5.3" long). The 4.7" goes on the S13WE and 5.3" goes on the 13WL as mentioned above. Maybe the next time you are working on the vehicle and have a wheel off, you can measure for everyone. I will do the mod this summer and try and sort it all out.
Old 01-30-2006 | 09:05 AM
  #48
koda4's Avatar
Have any of you guys that did this mod checked that the steel spare wheel also fits without contacting the new caliper?
Can one of you confirm this for me. I'm sure others would be interested too.
Thanks
koda4
Old 02-15-2006 | 04:45 PM
  #49
calrockx's Avatar
would the tundra rotors fit with the 4runner calipers? temporarily. i know the rotors are bigger, but not sure if calipers allow for some adjustment
Old 02-15-2006 | 05:04 PM
  #50
ebelen1's Avatar
No, they won't fit.
Old 02-15-2006 | 10:08 PM
  #51
914runner's Avatar
For a total factory look, could the tundra dust shields be used? I would rather do the extra work to put dust shields on that have the right clearence and not have to trim.
I can get a set of Sequoia front brakes for free. Are these the same as the Tundra brakes? I would tend to think they are?
Thanks
Old 02-15-2006 | 10:37 PM
  #52
FUZION's Avatar
I think they are, that's what i'll be using. cross drilled brembos.
Old 03-18-2006 | 05:18 PM
  #53
rocket's Avatar
Good question. I too would like to know.
I have a chance to get Tundra rotors and calipers for free (just pay shipping) and i already have 17" Sequoia wheels but still have the stock 16" steel spare.
Old 04-19-2006 | 06:16 PM
  #54
rocket's Avatar
Old 04-19-2006 | 06:21 PM
  #55
AH64ID's Avatar
Looks good, should have much better stopping power
semi-hijack
Can the same thing be done with a T100 and a 2nd gen?
Old 04-20-2006 | 10:11 AM
  #56
DoubleZero4x4's Avatar
There is only about 3-4mm clearance from the 16" alloys with the 4runner brakes. I cannot imagine that it would get much closer with the spare tire.
Just to confirm though, I will let you know after the weekend. I have the calipers and pads in hand, PowerSlot rotors due in tomorrow according to UPS. I want to do the upgrade tomorrow night (cooler). Goodridge G-Stop SS brake lines are not due in until monday so that little mod will have to wait until next weekend.
For everyones info the calipers are the 199mm with the 4.7" PF Carbon Metallic pads. I can tell you now that just by eyeballing it there is about 15% more surface area on the pad over stock 4runner.
If you dont hear from me until Sunday its because I will be at the Race here in Phoenix.
Old 04-21-2006 | 11:18 PM
  #57
OK WOW!!! The pedal seems much more responsive. The mod went without a hitch. I could not believe how much thicker my Tundra rotors are versus the 4Runner rotors. I am going to post some pics on my website on Sunday, so if anyone is interested I have quite a few pics that I took. Plenty of before and after. "Old And Busted vs. New Hotness!"
Even when the rear brakes were so far out of adjustment that the e-brake maxed out (fully pulled) the brakes seemed great. I have to admit that I feel like I am driving our 99 Camry when I am driving the truck now. Can't wait to install the Goodridge SS Lines next weekend.
Old 05-19-2006 | 08:32 PM
  #58
brazos609's Avatar
swept area
Am I the only one that noticed that the smaller(199mm/4.7") pad/caliper combo actually has a larger swept area than the larger(231mm/5.3). If the smaller Tundra set-up actually has a larger swept area(working surface) and fits with less work, why bother with the larger pad/caliper set-up?
Old 05-20-2006 | 04:05 AM
  #59
bamachem's Avatar
i saw that too... i was going to get them in my hands and compare them to the stock pads and also do some quick scale-off calcs of the pics w/ the 199 and 231 pads to see what the difference is.
Old 05-28-2006 | 01:58 PM
  #60
MorphiasX's Avatar
So will this mod work with my 1990 truck? And will it only work with 16" wheels? (I would use the 199mm calipers to avoid the extra work)
Quick Reply: Big Tundra brakes on 3rd Gen 4runner
