Bi*** of a bolt, how to get it loose?
Old 12-11-2007 | 09:25 AM
'97_5-speed_stroker's Avatar
Yeah, I have some too. But l think my largest is 3/4". I would go buy one, but I am in such a small town, that I doubt there will be a tool like that here. I will just wait until I go back to Las Cruces next week for Christmas break.
Old 12-11-2007 | 10:30 AM
pkt1213's Avatar
Well as long as you didn't go ahead and take the drain plug our first you should be ok.
Good luck. I also keep a 5' piece of of like 2.5" pipe laying in my garage for just suck ocations. Comes in handy for changing axel nuts or when you buy a 4runner from Toyota and you go to changed the oil and have to use a cheater pipe to get the drain plug out. You should have head the words I said about that.
Old 12-11-2007 | 11:08 AM
rdlsz24's Avatar
I hate when I can't find 6 point sockets in the bigger (20mm+) metric sizes
Rob
Old 12-11-2007 | 11:10 AM
pkt1213's Avatar
For changing the axle nut on my Probe I had to have a 27 and 28 or something like that. The new one was 1mm smaller than the one I took off. Same threads and stuff but the ones you can fine are m- expencive.
Old 12-13-2007 | 11:09 PM
  #25
beatenyota's Avatar
1. Heat the area around the plug until it is cherry red. this will expand it so the plug will become loose. If you heat the plug, it will just get stuck in more.
2. Get a wax crayon or candle, and rub it around the plug where it screws into the housing. The heat will suck the wax into the threads and break out any rust/corrosion
3. Back out the plug like buttah.
4. if it starts to squeal, re-heat.
Old 12-13-2007 | 11:33 PM
  #26
seanz0rz's Avatar
Guest
i used a pair of channel locks, with a 4 foot pipe on the end of one of the handles.
Old 12-13-2007 | 11:50 PM
  #27
MillerPKA's Avatar
great tool trick sean. i haven't read this whole thread but take it to a shop and have them take an air tool to it, manually tighten and go back to where you were working on it
Old 12-13-2007 | 11:56 PM
  #28
Ringmaster's Avatar
Buy a new plug and gasket.
Use a cold chisel and a hammer at the edges of the old plug to knock it loose.
Apply anti seize to the threads on the new plug, install.
Old 12-16-2007 | 10:52 PM
  #29
Thanks for all the tips guys. I got home this weekend and finally got it off. I went to Harbor Freight and bought some stripped lug nut remover sockets. They are 1/2" drive sockets reverse threaded on the inside. They cut their own threads in the bolt and it comes right out. I put the 1" socket on the bolt, threaded it on, and got a 3' cheater bar on it. Piece of cake!
Old 12-16-2007 | 11:10 PM
  #30
Man4God's Avatar
Originally Posted by pkt1213
+1 on the torch to heat it up. PB blaster works wonders. Also beating the hell out of it. I dont' know if you can but a stripped bolt removing socket that big at a local parts store. I have some but I think they only go up to like 17mm.
+1 PB and heat. I had a heck of a time getting my drive shaft loose from my IRS Cobra. PB for an hour then a torch for less than a minute did the trick.
Old 12-17-2007 | 07:29 PM
  #31
mheart624's Avatar
good you got it off, i m a dealer flatrater..this is really common..i use a airhammer and chisel takes 2-3 seconds installed a new plug with washer..
1uzRunner
63
11-10-2018 04:58 PM
wberry85
04-06-2018 09:45 AM
Pocoyota
09-08-2015 03:41 PM
eggens
09-05-2015 01:16 AM
Aaron Logan
09-03-2015 09:08 AM
