Belden vs NGK vs Denso plug wire sets
Old 11-25-2013 | 08:21 PM
  #41
TheDurk's Avatar
Originally Posted by Zealous
I think this is probably the right place to post this so I'll post again.
I'm looking to replace my OEM spark plug wires. I'm not concerned about getting OEM because I'm supercharged and interested in performance. I've looked on the web to no avail about the difference or compatibility of the NGK TE66 to NGK 4412 wires, especially for my specific application. I've read of gen 3ers using both, but nowhere can I find information about the difference between the two. Any input would be groovy.
Also, I just ordered some new plugs, after getting the NGK plug code manual, and the printout of the entire part number to stock number of the NGK catalog, here:
NGK Spark Plug Codes
http://www.ngksparkplugs.com/pdf/StocktoPart11x17.pdf
I haven't seen the topic of the difference between the plug wires anywhere so fire away.
2001 Toyota 4Runner SR5 4X4 3.4L V6 Auto Supercharged
4412 is the stock number, TE66 is the part number--exact same wires--no difference at all. The 4412 is like the 4-digit stock number for spark plugs and the TE66 is like the alphanumeric part number (BKR5EKB-11, for example that has a stock number of 3967). To confuse it even more, NAPA carries the same wire as NGW 4412
S/C issues I leave to others.
Old 11-26-2013 | 03:50 AM
  #42
Zealous's Avatar
Der
lol. Well that makes me feel like a flaming idiot. haha. Thanks Durk for clearing that up.
Old 11-26-2013 | 09:23 AM
  #43
mtvp's Avatar
I'm not sure where this leaves me. I replaced the plugs with the single tip BKR5EIX-11 Radium . That was 11 months ago and have not had a bit of trouble. No check engine lights ,good performance, good gas mileage. Is there really an issue.
It seems like the OEM plugs that I took out where single tip plugs from 1998.
Old 11-27-2013 | 10:14 AM
  #44
2Whlin's Avatar
OEM, should have been double tip? I just replaced my plugs and wires on a 96 and got them from the dealer. They were Denso double tip brand and the wires were still Somitoro or something or other? Sames plug wires I had there and the ones before. Truck runs noticebly better, seeing as eye's an idiot and let these go almose 100K!!
Dam were they wore out!!
Old 11-27-2013 | 07:58 PM
  #45
Zealous's Avatar
sorry. answering from my phone and got this reply screwed up. read half way down
Yes, well I have a 5vfzfe motor, 3rd generation, and so research about the ignition system. I forget what it's called, but the plugs fire twice each rotation offthe piston, once on combustion cycle, and once in exhaust cycle. this means that the plugs need to be at least double grounded. Do some reading on it
Old 11-27-2013 | 08:02 PM
  #46
Zealous's Avatar
yes double tip is double ground. it only fires off off one tip and that is what you need. most people don't know that but obviously the dealer did. these motors have a weird ignition system that most people don't understand.
Old 12-18-2013 | 06:01 PM
  #47
RAD4Runner's Avatar
Denso or NGK Spark Plug Wires
Relocated to new thread.
Old 12-19-2013 | 03:57 PM
  #48
TheDurk's Avatar
Hi guys,
One of the NGK spark plug wires I got from sparkplugs.com (SKU: TX99A
ITEM : NGK9799)
has developed a crack after just under 2 years. I expect wires to last longer than that.
Do you think it's indicative of NGK quality and I should get a Denso instead?
Or could it be just a fluke so should I stick to NGK? (Sparkplugs.com will give me some discount for repeat order).
Does anyone have any experience that sets NGK and Denso apart?
Denso DENSO Part # 6714003 is actually less expensive than NGK9799 from Rock Auto.
You should post in the 2G 4Runner forum where the 22RE's are. 4Runners on here use different NGK wire sets and I have never seen this kind of complaint.
Old 12-19-2013 | 05:08 PM
  #49
RAD4Runner's Avatar
Old 03-01-2014 | 09:54 AM
  #50
DRCOFFEE's Avatar
Update on the Denso TT spark plugs
Today at 177,500 miles (16,000 miles since the install) and I have decided to remove the Denso TT plugs. Upon inspection, the plugs in cyl 2, 4, 6, all looked fine and held their gap of .044. The plugs on the passenger side did not; 1, 3, 5 all had opened the gap to .049. Closer inspection shows no signs of wear. My best guess, the heat has softened the ground and allowed the gap to open up.
Lesson learned. I will go back to the Denso double platinum, double ground spark plugs.
What concerned me was to loss in MPG from 22 to 14 recently.
FWIW I wanted to let everyone know if these plugs were a good choice for our trucks. No.
Old 03-02-2014 | 05:53 AM
  #51
wyoming9's Avatar
Red face
At least you were honest with your findings.
I use the Plugs from Toyota and change them about once a year as well as the wires on both my 3.4 engines
Old 03-02-2014 | 08:04 AM
  #52
TheDurk's Avatar
Wires every year is overkill. I ran my factory Sumitomo's 80k and have 80k on my NGK's. Never had a misfire. I get my OEM NGK plugs from NAPA and change every 30k (NAPA is 15 miles closer than stealer.)
Old 03-02-2014 | 09:25 AM
  #53
wyoming9's Avatar
Red face
Running @ 60,000 a year I feel it is cheap insurance It is my work truck so I don`t mess around.
I also have a spare new ECM just in case.
During the non glacier months my stuff is delivered .prices are better from Toyota Then Napa
Old 03-02-2014 | 11:51 AM
  #54
TheDurk's Avatar
Hehe, that's different. For most people, it's overkill. 60,000 @ avg. 40 mph is 1,500 hours or 187.5 days behind the wheel. When do you do any work?
I service a Hyundai, a BMW, the Toyota, and a Farmall tractor, and all get their filters, plugs, wires, etc. at NAPA. It just makes my life so much easier, and in most cases it's cheaper.
There's always more than one way to skin a cat.
Old 03-02-2014 | 12:07 PM
  #55
wyoming9's Avatar
Red face
Most days are 16 hours.
What sucks is driving 4 hours to say "this switch needs to be up not down"
8 hours travel minimum 1 hour on site
I get on the average 4 hours sleep on a good night.
No wonder I don`t get things done at home.
smthwsn357
05-01-2024 08:28 AM
sandyota
02-04-2021 12:16 PM
msane99
07-17-2015 11:13 AM
nick b
07-11-2015 05:38 AM
88runnergomas
07-09-2015 02:12 PM
