Battery Cable Extension
For you guys that have done an upgrade to an Optima Battery - I am installing a blue top, and need to buy an extension for the OEM battery cables, rather than rip them out completely and install longer ones. Where do I find an "extension"? A couple of stores that I have checked have never heard of such a thing..... Is there another way to do this? Thanks for your answers...!!
Re: Battery Cable Extension
https://www.yotatech.com/forums/show...dual+batteries
He just extends his OEM ones. I hope this helps!
First of all, how far do you need to extend? You can easily find 4 gauge terminal connectors of at least 25" at almost any auto parts store. Then to connect to your existing wires, run by an audio place and pick up some 4 gauge end terminals/connectors and just run a bolt through the two to connect. If you are making an extremely long line, run to the audio store and grab a bunch of 4 gauge wire and use that to re-route...should be very simple...I'm running 3 optima dry cells.
Billy
Billy
Billy
Billy
I beg to differ...run to your local auto parts store and tell me what gauge 90% of the battery leads they stock are...and honestly, 8 gauge is even strong enough for the majority of leads if the draw is not too extreme...please don't get me started with electrical...one could probably conclude that due to the fact I mentioned I am running 3 ultima's, that maybe a battery isolator or two is involved somewhere in the mix, as well as wiring in parallel, and most likely a few amps that draw in excess of 10,000 watts RMS...or maybe i truly have no clue about wiring and electrical situations. Actually, I was wondering if you could explain a couple of terms that i think is apply to this discussion somehow?
I hear people talking about 1'0 wire all the time, I'm assuming that must be a very small wire cause they never seem to say what size of gauge it is?
And two, a friend of mine has this vehicle, or maybe it was mine...I can't remember...but one day we turned on the stereo really loud and this little meter thingy gave us a reading of 176.2 Db...do you think you could help me to interpret what this means...I thought D.B. could maybe stand for dead battery?
Thanks so much for all your time and help. Sorry for my ignorance, but my only true way to learn these kinds of things is by consulting someone like you who has great knowledge in this specific field.
Billy
Billy
disconect the bolts that hold the wires to the frame near altinator, that should give you enough play. Next remove the ground and connect it near the grill. I am currently using a bunjy to hold it down. It has worked perfectly. Remember to connect hi volt stuff (amplifiers, winches, altinator) to the top and not the smaller terminals. use those for lights and minor excessories
Any car audio store will know exactly how to do your extension. The all stock power cables and sell them by the foot they also have cool power spliters for running multiple things.
- www.jcwhitney.com
Using the positive extension and a riser board is a quick, cheap, easy, and secure way to install the optima.
[B]I beg to differ...run to your local auto parts store and tell me what gauge 90% of the battery leads they stock are[B]
Now, I won't sit here and argue this with you as we each have our own opinion.
I personally wouldn't use anything thinner than 1 gauge since the longer cables have more resistance. I used 1 gauge wires to re-locate my winch switchbox under the hood with cable and copper solder-on terminals for a while. Everything came from a welding supply place up the street.
Originally posted by JSharp
Silly question here - Does Optima not make a battery with the reverse terminal layout as required on our Toyotas??
Originally posted by <96 Runner>
Autozone doesnt know crap.
Originally posted by jeremy
the orange top is now red
