Balancing tires on 96-02 Haweka vs Hunter flange adapter?
If you've ever had your tires balanced on a 96-02, you know it can be frustrating as your truck will shake if a lug centric adapter isn't used. There was even a TSB out from Toyota saying the Haweka adapter must be used to eliminate vibrations, etc. My local shop has the new Hunter machine with "Hunter" lug centric adapters with the fingers and I'm wonder if this will work as well as the Haweka version adapter?
Anyone know?
Anyone know?
yes.
or yup, as it were
and that means they have to have the extra direct-fit collets that fit your wheel.
only if they do it right, but it is all up to the operator
or yup, as it were
Jcrawl94
10
10-24-2015 04:34 PM
priest16
15
08-06-2015 07:43 AM
