Is it bad to....
I do this often.
My yota is a 3.slooow automatic, I use 2 low a lot, when I have a load in the yard, or am using my truck to pull something heavy, I moved some LAAARRRGGGE stones that the excavators pulled out of my property when they installed my new septic system, and they are about the size of a Yugo! I also use 2Low when I am wheeling quite often.. There are a lot of trails that I run that you don’t need to lock the hubs if it hasn’t rained or if there is no snow, my Revos have helped out a lot with this! I put the trans in drive, and let it shift into 2nd gear, I can then basically crawl my way through just about anything in 2 Low, and it doesn’t heat up the trans or strain the engine at low RPMs. This is nice since most of the local trails are about 25 miles away and if you don’t need your hubs locked, why lock them for the road!
Originally Posted by jimabena74
also a lot of people use it on boat ramps when entering or exititng the trailer into the water
Originally Posted by arjan
I used it for backing up the trailer around corners and in tight spots. It goes slow enough so you don't have to ride the clutch.
Blamalam
08-16-2015 12:29 PM
nonstop
7
08-11-2015 09:26 AM
