ARB and frame strength
Old 01-03-2005 | 12:00 PM
dlbrunner's Avatar
I have seen quite a few posts regarding the ARB bar on tacos, and it has been said that the USA version is 1/2 ton and hence a lighter duty version than it's overseas cousin's.
Does anyone know if this applys to 2gen runners and 89-95 p/u? and if so any difference in the Frame strength?
A related question, I remember in the early 90's seeing 1 ton 2wd pickups, is the axle much different than the standard rear toy 8" ?
I was just thinking if parts were somewhat compatible a full floater retrofit might be possible. Any thoughts?
Old 01-03-2005 | 12:29 PM
Brendan's Avatar
i'm pretty sure that the 89-95 trucks have beefier frames than those of the tacomas, but just how much beefier, i do not know.
Old 01-03-2005 | 02:17 PM
dlbrunner's Avatar
bump, any overseas people want to chime in?
Old 01-03-2005 | 06:17 PM
jimbo74's Avatar
the rear end in the 1 ton is the same as the standard 8" toyota rear end.. normally they jsut have differnt gear ratios than a normal truck would have..... also it being a 4x2, its gots a 5 on 4.5 bolt pattern and a spring under axle setup.. the rear ebrakes are the same as the otehr 4x2 trucks, which are differnt from the ebarake setup on the standard toyota 4x4 rear end....
Old 01-03-2005 | 06:29 PM
dlbrunner's Avatar
Wow less lug nuts on a 1ton?!?! that is different. no full floater for sure?
Old 01-03-2005 | 06:51 PM
914runner's Avatar
Originally Posted by jimabena74
the rear end in the 1 ton is the same as the standard 8" rear end.. normally they jsut have differnt gear ratios than a normal truck would have..... also it being a 4x2, its gots a 5 on 4.5 bolt pattern and a spring under axle setup.. the rear ebrakes are the same as the otehr 4x2 trucks, which are differnt from the ebarake setup on the standard 4x4 rear end....
Nope, not correct. The 1 tons have Full floater rear axles(I am very very certain on that), and rear disk breaks(I am pretty sure on that). As for the lug pattern I cant really remember but I thought they had the 6 X 5.5?...
Old 01-03-2005 | 07:11 PM
dlbrunner's Avatar
I thought those were full floaters, As for disks, not sure they must have a slightly different setup than regular 1/2 tons since there are 2 wheels on each side. If it is possible to do some sort of a retrofit that would
Old 01-03-2005 | 07:14 PM
rockota's Avatar
Nope - yer wrong.
1-ton duallies had a the full floaters... But Toyota made a lot of "1-ton" SRW's with semi-floaters...
As to the original question..
ARB mounts in 12 places on the 2nd gen 4runner, if I remember correctly. Two on each side of the body-mount, two on each "tow" point below the frame rails and two on each factory bumper mount...
The frame is pretty strong, but if you plan on doing extensive winching, I'd consider bracing the front crossmember with FRORF's re-enforcement pieces.
bkg
Old 01-03-2005 | 07:24 PM
dlbrunner's Avatar
I was refering to the 1 ton dually, I thought those were the only 1 tons, what is a SRW?
What is FRORF, Sorry, but I am a little bit of a newbie with the acronyms
Old 01-03-2005 | 07:41 PM
jimbo74's Avatar
srw is single rear wheel....
i dont know what the duallies used something wierd with huge ass lugnuts.. looks liek a ford f350 rear end.. seriously....
trust me, im right about the 1 ton though.. my neighbor has a red one... and i park my truck behind him everyday....
Old 01-03-2005 | 08:09 PM
rockota's Avatar
Sorry about that... FRORF - Front Range Off-Road Fabrication.
www.frontrangeoffroadfab.com
Frame Brace:
http://www.frontrangeoffroadfab.com/frame_brace.htm
bkg
Old 02-03-2005 | 09:04 AM
dlbrunner's Avatar
This thread should be renamed the 1 ton axle thread. I looked at a one ton last night and it has 6 lugs for sure, but a larger pattern, maybe a 6 or 6.5. It appears to be a full floater because of the hub looking thingy. Boy would I like to get my mits on one of those just to take apart and look at
justdifferentials
Just Differentials
06-13-2022 08:40 PM
justdifferentials
14
06-11-2017 09:36 PM
choppe777
05-16-2016 09:00 AM
justdifferentials
09-05-2015 07:52 PM
AkitaDog
09-03-2015 10:01 PM
