ARB bullbar install on 2nd Gen 4-runner?
Does anyone have experience installing a ARB bullbar on a 90 4-runner? What tools might be needed? Any grinding or cutting of brackets or frame? Will the factory turn signals fit? Thanks
Regular ratchets and box end wrenches are needed.
The bolts that go straight into the frame from the front are somewhat hard to get to, but if you have a ratcheting box end, then it is slim enough to get in there and work without pulling off the bolt head.
I had to hog out some of the holes on mine so that I could line them up with the holes on the frame.
The turn signals will fit, one screw goes in from the front, one from the back.
Doesn't get much easier. It is helpful to have someone to balance it while someone else starts the bolts, but if you are one with the force, you can do it alone.
Thanks guys, I'm driving it to Tulsa for Outdoorfever and installing it on his 90 4-runner and did'nt want to have any supprises on the road without all my tools.
Corey did you ever look under your rig to see why you don't have bolts in those holes most under the engine by the skid plate in this picture
No, never got around to it.
To cold here now, we have ice on the ground
I'll get under there someday and look at it real close, and also find my box of left over install stuff from the bumper.
Also Corey someone on another forum said that something had to be removed first before installing the bar and that it wasn't in the instructions anywhere. What's that all about?
Yes, it was Josh who use to have a 2nd gen, and now he owns a TJ Jeep.
There is a hidden plate or two under there that must be removed prior, or the bumper won't slide into the channels underneath.
This does not apply to all 2nd gen 4Runners, only certain years, and mine was one of them.
I do not have pictures underneath to show you.
I have the parts in a box somewhere, but that somewhere eludes me right now or I'd get you pics of the parts.
Originally posted by Arnold
On my '86 I had to cut the stock bumper mounts off. I assume you'd have to do the same on the Runner.
Originally posted by mt_goat
Oh I hadn't heard anything about that, what did you use to do that? So now you can't go back to your stock bumper without welding those back on?
Originally posted by ALBPM
so, how's the new Bumper outdoorfever?????
How was the install??
Here are two pictures of the finshed project. front view and side view
Looks nice and solid
We didn't have to grind anything. A few bolts were hard to get lined up at first. There was some foam stuff that we had to push out of the way on top of the frame cross member, I don't know what that's for but it was in the way. And we had those two bolt-on pieces at the bottom of the frame that had to come off.
hey almbp and dale, yea its awesome. thanks for asking and thanks again to dale that help me put it on. its gotten muddy already it really adds to the 4runner. i love it. and btw, how do i resize pictures. it sucks not being able to show her off . thank ya
06-01-2021 02:51 PM
cgilley
07-15-2015 04:32 AM
Steezy96yota
07-06-2015 11:00 AM
