Aquamist Water Injection
Originally Posted by MTL_4runner
That's a good point Mark, it is critical to ensure you always have a matched set of injectors because the ECU has no way of knowing that injectors have slightly different flow rates and will fire them all exactly the same duration. The biggest issue with using undersized injectors is that as you get above the 85-90% duty cycle the injector starts doing strange things and may not open the duration asked for by the ECU and thus cause a random lean condition. I think 370s or 440s would be a good choice over the 318s for sure.
Originally Posted by Greedy
I was in the same boat deciding between the 370's and 440's for my turbo set-up. Brian at URD said that the 440's would be a better match for me but that they can be hard to control at idle and low throttle with a piggy back fuel controller. He said that they lose some of their "resoultion" and do not provide as smooth throttle response as a 370 would. I was only going to use them as a temporary solution untill they released their port fueler. If marks secret weapon is a standalone fuel managment then it's a different story URD could explain it better than I can but the impression I got is that we should only run the 440's with the piggy back controller if there is no other option.
argh... I forgot about the 440's being a bear at idle. The FTC and SMT piggybacks are only 8 bit controllers so they can only have so much granularity when it comes to spliting microsecond hairs.ugh.
Now I'm wondering if I should stretch a set of 370's.. They'd be a lot less stretched than my 305's are now.
Hmmm... the MegaSquirt is a 16 (18?) bit controller. I know it's got 1us resolution. Man, maybe I should open THAT can of worms again. That'd be a nice weekend project - replace the ECU!
Mark---If I might make a suggestion.
From what I understand, trying to control 440cc injectors with a piggyback at anything other than WOT can be a real pain in the ass. 370cc injectors may not be much better. Have you ever thought about making up a 7th injector setup? All you would have to do is mount a large injector, tap a fuel line to it from the fuel rail, then control it with the URD additional injector controller.
On my setup I run the 6 stock injectors. Gadget said he flow tested the stockers at 238cc. I also run the 7th injector from TRD that is supposed to flow 630cc. If you do the math it comes out to 238cc X 6 = 1428 + 630cc = 2058cc total. If you divide by 6, that equals to me running 6 injectors at 343cc each. I don't know what my injector duty cycles are but the system holds a 12.0 AFR running 304 rwhp at 11 psi just fine with the stock FPR and a Walbro 190 fuel pump.
TRD uses the EGR port on the blower housing to mount the injector. The good thing about a setup like that is that you can use the stock main injectors without the need of a piggyback to control them. No sensor (MAF) signal is altered. The engine runs as stock unless you are in boost and the extra injector kicks in.
My extra injector setup works flawlessly with no closed loop or tuning issues. You might want to give some thought to a setup like that.
Sorry about the thread jack Ivanr
#25
ARGH!
Okay... back to the think tank. argh.
argh. argh. argh.
#27
#28
#30
Is anyone running the 370s successfully right now?
I just got a SCREAMING deal on a set of 6 - SCREAMING I tell ya'. I figure that the worst that can happen is that I resell them for more than I paid for them. I _expect_ problems in controlling them down low, but I'm willing to give it a shot.
I should have them "soon", though I'll have to wait on an order from URD to get the connectors.
#31
Originally Posted by midiwall
Okay, against everyone's (and my) better judgement, I'm going to try 440s.
#32
Good luck Man! I hope that they run good for you. Are you going to be running the 2.0 pulley as well then??
LotOMiles
09-14-2015 11:45 PM
