Any '03/'04's tried the deckplate mod?
Old 11-02-2003 | 11:11 AM
momo.75's Avatar
Yes, I have already doe a search, but didn't see anything on this.
I was wondering if anybody had tried this on a new V8? If so, was there any problems and could you tell a major difference? I saw K&N has their intake available for the V8 but I know the mod is much cheaper.
Old 11-02-2003 | 01:54 PM
Good Times's Avatar
I think I saw someone do a deckplate mod on tundrasolutions.com.
If you're interested in doing this mod, it should be relatively easy to do and should have no problems. As for performance gains, can't really say but you figure you may gain 1hp?
Old 11-02-2003 | 04:45 PM
nrgetic99's Avatar
Have you had a good look at the airbox ?
I am not sure there is anywhere you could put a decent sized deck plate.
David
Old 11-02-2003 | 05:20 PM
fourunnabilly's Avatar
Guest
I did before I adapted the tundra FIPK. Just cut off the front and left side of the airbox, leaving the bottom to attach back to the metal, and the right side to shield the cold air...definitely seemed to help. Was gonna post pics, but threw on the FIPK before I did. I used some butel (sp?) to secure the K&N to the remaining bottom part of the box. This should be pretty self explainitory...also turn the little round plastic air tube around in the fender to deflect more cold air into the filter. Let me know if you need any help. This is not really a deckplate mod, just a cheap way to open up the air to the filter and gain a few hp. It is not a reversable process, as you would have to buy a new lower half to the air box. Good Luck.
Billy
TheBFA
02-15-2020 07:55 AM
punks_is_4x4
05-31-2016 07:03 AM
voiddweller
53
02-01-2016 06:46 AM
oldblue
09-28-2015 05:07 PM
Project90
09-25-2015 12:40 AM
