Antifreeze Question?
Ok, I did a search and got some info, but looking for a little more help please, I have a '98 4runner 3.4 and need to top of the coolant, should I get Toyota brand coolant from a dealer or is it ok to top off with regular. When I flush out system next I should use toyota brand right? but what about to just top off?
Here you go:
The Red Toyota coolant is a low silicant formula unlike the "green" stuff. Silicates turn into acids and eat up your aluminum. the block/heads/water pumps are all alluminum!! So to top it off yes, use toyota coolant or straight water. just make sure that your specific gravity (temperature range) is good for your area. Frozen blocks are not fun!
Originally Posted by shiftless89
Here you go:
I've had my 84 Camry for about 12 years and have always drained and refilled with Prestone every year. I have never had any issues. To my knowledge (at least since I have owned it) it has never had the water pump replaced-or really much of anything else for that matter.
I usually recommend stock for most stuff, but I just wanted to throw that in.
Oh yeah, do as Tacomanator said and used distilled water. The tap water contains minerals that cause deposits over time and probably do more harm than anything else.
TJWilly
07-31-2015 03:05 PM
