another "wont start" thread
I have a 2000 4Runner Limited and for months everything has been working fine. The starter was replaced a few months ago, and the car has since been working perfectly until just a while ago when it simply would not turn on
The 4 wheel drive indicator is blinking on the dashboard, but I havent used that feature in months, which i found odd.
The battery is fine, the starter is new, and I seriously dont know what to do. Ive been researching the problem and have yet to come up with any results to fix it, so ill be more than happy if anyone could help point me in the right direction to fix it
use a pair of jumper cables from the negative off the battery to the frame.. could be a simple grounding problem.. Inspect all the main grounds and postive hot wire to the starter. if you have any green color wire cut it out the corrisoin or just go buy some new cables at the part store.. should be less then 40 bucks out the door.
What was it that fixed it?? please always post the fix so future readers know!!!
If you don't post the fix then how will that help the next unfortunate soul???
Glad you got her fixed this is great!!!
joeynational
09-05-2015 02:54 PM
86 87 4Runners
09-05-2015 07:02 AM
86 87 4Runners
09-02-2015 04:54 AM
