Another "What does this plug go to?" question.
I was putting in a head unit this morning and I saw these two plugs. I think one is for an antenna (even though there is an antenna is plugged in to the new head unit) and I have no clue what the white one is for. I don't know if I inadvertently unplugged it or what. Thanks for the help.
The white squarish looking connector- plugs into the back of the radio bezel-near the clock-I'm not 100% sure but I believe it's the wiring connector for the rear window operation.-Beware there are 2 places that connector will fit-one is a dummy plug receptacle and does nothing-so test all your functions before spending all the time to snap back in the bezel.
The other antenna connector male plug is your diversity antenna plug-the antenna embedded in your passenger side cargo area glass that resembles defroster grid wiring. Some of us have "adapted" that plug to serve as the only antenna or used a Y connector to combine the 2 antenna plugs. Member "Rockslide" has a most excellent writeup on this-and it's a good time to add a toggle switch for manual control of your power antenna if so equipped.
Just a tip JBurt- if you put some details of your vehicle within your signature it saves those prelim questions of what vehicle is being discussed. But your avatar picture helps with that also.
Michael1963- thanks dude!
That white plug goes to the radio amplifier (that silver box in the background in your pic) and it plugs into the back of the stock radio. I removed the amp when putting my head unit in because it was in the way.
glad to help-sorry for my confusion on the white plug. That RockSlide is a great member and I was so glad to have seen that post-thanks for linking the thread.
My antenna just stays down all the time now. The rear window antenna gets perfectly acceptable reception for my needs.
rushw
07-18-2015 01:46 PM
