Another Rear Window Question (searched)
Mine is pretty simple, the key in the tailgate works fine up and down and the switch does nothing. I looked over 4crawlers site, but I'm still not sure where to go.
Do I need a new switch, or one of those relay/module things? Any help would be great.
Thank You!
Lamm
Thank You!
Lamm
i had problems with the switch on mine. it was pysically sticky to the touch, and you could see were countless soda/whatever had been spilled on it. (this was right after i bough mine used)
I took it out and cleanded it with a toothbrush and it then actually "clicked" right and its been good sence.
<Edit> now that i think about it, it would go down with the switch, but not up, so i had a good idea it was a switch problem. (key worked fine same as you)
theres a rear window relay behind the driverside kickpannel. might test it out... (big black boxy thing, if i remember right.... it says on the front of it...)
If the key works fine I would check the switch. The easy way to check if it is the switch is to short the connections (on the wire that connects to the switch, not the switch itself) and see if it makes the window go up and/or down. I did that to check my back-up light switch and when the light came on I knew the switch didn't work.
Follow the advanced troubleshooting tips that I have on the page:
- http://www.4crawler.com/4x4/CheapTri...leshootingTips
A clicking relay is one of the troubleshooting tips listed on the page. Read it and I'm sure you will find the answer.
Well the click I hear is the switch, not a relay. Anyways, the shop has the 4runner right now due to a miss problem so it will be a few days till i can go it it, for now I'm just taking notes. I will try jumping the switch, and if its still bad, it must be a realy.
Lamm
Lamm
Again, that is a clue, and you did not mention the click in your PM to me. If the switch clicks and the relay does not, then the signal from the switch is not getting to the relay. So either the switch it bad, the contacts are dirty, damage to the wiring/connectors between the switch and relay or the relay coil itself is burned out.
Does the mechanical click of the switch mean anything other than it moved?
Roger, you remind me of my dad a lot, he is in IEEE too. Not ment to be offensive in any way, just a starnge observation. You even look a lot like him.
Anyway, back on topic, I will prob need to hunt down a switch. Anyone have a price from a dealer?
Thanks!
Lamm
Thanks!
Lamm
Look at the workings of the switch. It has a mechanical part that you push with your finger and it moves some stuff inside. One of those things that move is a pair of metal contacts. So one possibility is the mechanical part is messed up, common problem on the power window switches: http://www.4crawler.com/4x4/CheapTri...l#WindowSwitch
Or the metal contacts could be dirty, pitted or somehow messed up. Only way to know is to pull it out, look at how it works, test it (w/ ohm meter or test light) and fix or replace it as needed.
Originally Posted by 4x4Lamm
Well, as luck would have it it works again. It makes no sense to me but I'm not complaining. Thanks for all your help.
Lamm
Lamm
06-01-2021 01:51 PM
TURBOrunnerNM
07-22-2015 11:01 AM
icentropy
07-09-2015 02:12 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
