Another MAF/P0171 Thread
Ok, I have a P0171 CEL light with my 1997 Toyota 4Runner V6
Yes, I have cleaned the MAF sensor with no luck as the code going away
Yes, I do have a new fuel filter on the car (Toyota OEM)
I recently had my car tuned up by my mechanic as well as some other things (he replaced the seal on my rear differential, because it was leaking gear oil)
I have an oil based K&N filter
I have the deck plate mod on my 4Runner.
ok, my question is... what can I do now?
I can buy a new MAF sensor, but Toyota wants 600 dollars plus! (Toyota Part No. 22250-20020), auto zone 220 + 40 core charge. I have been reading about a toyota 100 dollar replacement via the other threads on this board concerning this problem. Does anyone have the part no. for that?
Are there any other possible solutions to this?
and just fyi, this came on about two months ago, and since i deemed it to be not a major mechanical problem, I have still been driving my car to and from school.
Thanks in advance guys
David.
David.
If you've cleaned it with brake cleaner (electrical contact cleaner won't work for squat so if you used that, they you'll need to do it again!), reset the ECU and it still came back, then get a used one off eBay. That same MAF was used on several different vehicles so you can almost always find one for sale. You might want to ditch the K&N since this is a common issue with those. Also yes, the retail on a new MAF for 96-98 4runners is $568.53 so a $600+ repair bill wouldn't surprise me one bit.
List of vehicles:
http://www.ultimateyota.com/index.ph...11253#msg11253
Example of used ones:
http://motors.search-desc.ebay.com/s...trypage=search
List of vehicles:
Why do you think its your MAF? Unless the code is different for a '97, that code is a lean code. I got that after adding my S/C and when I did my fuel mods, I increase my fuel via my piggy back puter. Would a bad MAF trigger that code???
List of vehicles:
List of vehicles:
Thank you for your post!
No, I have yet to re oil my K&N, but the general consensus on this board is against the K&N, so probably early of next year, when I do my oil change, I will get an AMSOIL air filter with my oil change.
joeynational
09-05-2015 02:54 PM
86 87 4Runners
09-05-2015 07:02 AM
86 87 4Runners
09-02-2015 04:54 AM
