another diff fluid question
I have 190k on my 1996 4runner. I dont ever remember chaning the diff fluid on it. Would it be wise to change over to synthetic at this point? and if so, is there anything i need to do differently when changing to synthetic?
Matt
Matt
i checked the rear diff and it seems that its not leaking. i think the pinion seal is leaking? thats what a buddy of mine told me i checked my extended diff breather and everything was fine. any ideas on why its leaking?
thanks
Matt
thanks
Matt
Originally Posted by kevin444
I cant get the diff drain bolt off. I dont have a 24mm combo wrench.
Matt
Matt
you need a 6 point. trust me, every time i try to break one of these 25 year old drain/fill plugs, they strip. stupid design, there's no meat to grab onto.
if you strip one badly, the best way to go is get a chisel and a hammer and try to break it loose that way. after that, upgrade to the plugs that take an allen wrench rather than a socket...i can't remember the part # off the top of my head
From Marlin Crawler
Low Profile Magnetic Drain Plugs
These factory replacement drain plugs feature a built in magnet to help remove metal filings that accumulate during normal use. The much smaller, round head design reduces chances of rocks grabbing edges and loosening plugs while on the trail. Requires 10mm Allen socket to install or remove. Low Profile Magnetic Drain Plugs $4 (each)
dont forget to change the crush washers while youre at it. they are cheap and will ensure a good seal, torque to spec and you are good to go. jim, those allen head plugs are a great idea, im going to find some to replace on mine.
lee
lee
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 03:08 PM
Athansinis
07-27-2015 09:38 AM
Steven.m.paulk
07-24-2015 02:44 PM
scottyg486
07-19-2015 06:34 PM
