alternative to rock sliders??
I'm looking to remove my factory running boards, but would like something sleek like sliders. Not looking for something I have to weld on. Is there anything out there that looks cool that I can bolt-on??? thanks
How about going for function rather that to just "look cool" ? And if your going in the "cool" direction, weld on is cooler than bolt-on
Zipped the ones off my 3rd gen and you would have never known they were there.
Damn I miss this truck.
I'm in the process of ordering sliders also. I went with someone local to reduce shipping, but they are typical of most of the lower priced ones listed in this link...
https://www.yotatech.com/50592922-post3.html
I chose the sliders from addictedoffroad. Functional and budget friendly. If You want 'cool' + 'functional' and have no budget, then check out Slee Slidersteps. They fab something that gives a look other than the typical round tube utilitaritan look.
If you have access to a welder, then there are plenty of places that sell the same type of slider as a piecemeal kit, which will save you a few bucks.
My two cents here is if you are looking for actual armor that looks "sleek" get your rails from Rocky Road. I have a bolt-on set up from them on my 2006 4Runner and they look great. Plus, these are the thickest rails I have seen (inner wall strength). They have saved me from body work and look the "best" out of any I have seen (cosmetically)
I have a set of "ugly" rails on my wheeling machine (1989 Truck) and they work well but stick out pretty far. I really dont care tho on that rig.
Check out Rocky Road's website: http://www.rocky-road.com/toyarmor.html
You could also go with weld on/bolt on, this is what I had a local fabshop called Badland Bumpers do for my '91 4Runner I had.
The plates and inner tubes were welded to the rig.
The sliderz had bigger outer tubes that would slider over the smaller diameter tubes that were welded to the rig.
One bolt per tube would secure them.
You can easily take off the sliderz this way to repaint them.
Of course if you sell the rig and put the running boards back on, you would have to cut down the tubes (maybe, maybe not) to put the boards back on.
I got this idea from some guy long ago over on Pirate.
His dad fabbed them up for him this way.
kawazx636
10-06-2021 04:03 PM
JookUpVandetti
09-30-2015 09:58 AM
Toys4parts
09-26-2015 02:56 PM
