All good, but bogging off start
Old 09-16-2009 | 06:52 PM
toy02's Avatar
My 4Runner runs perfectly 99% of the time, but lately (within the last 2 weeks) when I'm at a stop light idling for a while, it hesitates when I start going again. I have about 82K on the motor and changed the spark plugs about 10K ago, it runs fine otherwise. Not sure what the culprit could be, I'm thinking of running down the usual suspects (air filter, injectors, fuel filter, etc.) Anyone got any suggestions? Thanks for the help.
Old 09-16-2009 | 07:18 PM
eddieleephd's Avatar
I had the same issue till I started running a K&N filter.
I contribute this to less air restriction. TPS could be culprit as well.
Old 09-17-2009 | 03:01 AM
toy02's Avatar
What's TPS?
Old 09-17-2009 | 11:39 AM
TPS is throttle position sensor. This is an electronic component that tells the ECM where the throttle position is. from the tps and the MAF the ECM decides how much fuel to give the engine.
SEAFOAM is a choice for the injectors. put some in the fuel tank and drive.
simply follow the directions on the bottle.
Old 09-17-2009 | 01:48 PM
BigBallsMcFalls's Avatar
dirty MAF
clean it and tell us problem is fixed
Old 09-18-2009 | 10:30 AM
Originally Posted by BigBallsMcFalls
dirty MAF
I had done this many times thinking it may help but no. just the air filter actually did.
not saying it doesn't help at all but not noticeable in my exp. so what have you found?
Jmiller1023
23
08-06-2015 08:03 PM
Badger62811
06-26-2015 10:26 PM
jmc88runner
06-18-2015 04:39 PM
Skydigger
07-01-2002 01:39 PM
XtremeOff-Road
16
06-27-2002 08:32 PM
