Airaid MIT & True Flow filter
#41
Just installed the Airaid MIT yesterday, and there is a real diffenence in throttle response, especially in 2nd, 3rd on my auto. I also lost this weird engine rumble/vibration when topping out on those gears, probably due to the other intake tube with that airbox thingy.
The True Flow will be arriving on Monday, can't wait to see if that improves things also.
All in all a good mod.
Luis
Luis
#42
Are you sure?? My 97 has stock wires and they are Sumitomo. I have seen dyno tests that prove that Sumitomo wires are provide a better spark than an aftermarket $150 set of MSD's.
#43
Luis
Luis
Its alot louder than I expected. Around the 4000RPM range its got sort of an angry snort, but for everyday commuting you don't really hear that much. Could be in part to having the deck plate open. All in all its a very nice and simple kit. Installed in 10 minutes. I am going to re-install the stock intake, and get a baseline for power, then install the True Flow kit again, and test again. See what I come up with for numbers to justify the cost of the kit.
#46
I went and got the True Flow kit from Jason B (Thanks a bunch!!), and installed it the other day. I have to say the but dyno says theres something there. How much?? Not sure. I was hoping my Auterra software that I ordered would be in before I put it in but I couldn't wait any longer. The box was starting at me and I had no choice.
http://www.burtmanindustries.com/zoo..._truflo_int_96
#50
#52
What is your opinion of the AFE dry filter so far? It looks like a miracle drug in a sense, and am considering purchasing one.
#53
#54
Wow, JB.
You sure did pick an oldie!!
I had both the Airaid MIT and True Flow filter on my '99 4Runner and loved them both.
The MIT along with the deckplate mod really did help performance, not a big improvement in gas mileage but more power for same mileage - can't beat that.
Fink
Fink
#58
Here are links to BOTH for the best combo
http://www.burtmanindustries.com/zoo...n_airaid_96_02
http://www.burtmanindustries.com/zoo..._truflo_96u_v6
#59
Just installed the MIT, I dig it! Quite a bit louder and deffinately smoother acceleration on light acceleration...should help with MPG I am thinking...WOT I cannot tell a difference...but sounds good...cheers!
#60
Have you done the deckplate? If not, I highly suggest you do it - it will make the Airaid shine.
Fink
