Aftermarket Tach for my 99 Tacoma 2RZ-FE 2wd 4cyl.
I recently bought a tachometer for my 99 Tacoma 2RZ-FE. It has the 2.4 DOHC 4cyl. 2wd engine. I ran into one small problem. What wire ore where do I tap into to get the rpm reading??? Thanks in advance to all the replies with some info on helping me solve this problem
my brother did this install when he had his taco... i know you tap the rpm signal wire on the ecu... lemme check back in the toyota electrical manual when i get home an i'll post which wire and which plug.
94ofCanada
08-14-2015 07:37 AM
landrunner
08-05-2015 10:18 PM
Bflo338
07-21-2015 08:28 AM
