Advice Needed Broken Bell Housing 99 4Runner
Old 01-18-2016 | 08:56 AM
richdavies's Avatar
Bought a 4Runnner knew it had a broken flex plate. Pulled transmission out and found the bell housing cracked in half. With this much damage what else should I replace or scrape it? 224k miles on it, body is very good.
Concerned that when I put it back together I will find more major issues.
Thanks
Old 01-18-2016 | 12:16 PM
dropzone's Avatar
Fossilized
inspect the frame, mounts etc. Either someone jumped it or it was in accident.
If all you find is the broken bell housing, I would fix and drive on
Old 01-18-2016 | 01:21 PM
richdavies's Avatar
At some point in it's life it has been wrecked. I can see the frame was repaired and what I am fairly certain is a dent in the oil pan that matches the cross member perfectly, it could have been made that way, but I doubt it. This is my first 4Runner so I am a true novice. I would say the accident happened a long time ago because clear coat on the hood has already started to peal.
btu44
10-07-2016 09:03 AM
charlie_fong
12-28-2015 06:31 PM
elaketiger
12-28-2015 07:16 AM
ToYoda49
12-27-2015 04:04 PM
