Advice on coil spring compressors
Old 09-10-2007 | 05:36 PM
johnw999's Avatar
Is a vice required when compressing the front springs? I plan on using the sears craftsman compressor.
Old 09-10-2007 | 05:54 PM
seanz0rz's Avatar
Guest
i used to rent from autozone, but i just bought a set of craftsman ones, they are great, even though they dont technically fit the tundra springs.
i had a set of harbor freight ones nearly explode on me, DO NOT BUY THEM!!!
dont buy chinese crap!
as for using a vise, i didnt, i used sand bags or carpet or foam under the spring. i dont care about scratching them up though.
honestly, with quality tools, its not scary at all. man up and just do it.
Old 09-11-2007 | 05:12 PM
lanai's Avatar
The craftsman compressors work fine. Just be sure that the compressors are spaced evenly on the springs.
Old 09-11-2007 | 05:23 PM
frodin1's Avatar
I always grease the threads on them also. It'll keep you from shredding them if you do use an impact gun. If the springs are heavier I would just take them to someone with a heavy duty compressor. Cheap, safe and easy.
Old 09-11-2007 | 06:29 PM
  #25
GhostriderTx's Avatar
Let me ask the question a little different. If all you are going to do is compress the OEM springs enough to remove the shock and replace it - then what would you recognize. I think this would require less force than new springs
Old 08-23-2010 | 12:23 PM
  #26
Funrider's Avatar
This is a link for the safest and best you could use!
http://www.nationaltoolwarehouse.com...qx/product.htm
Old 08-23-2010 | 03:16 PM
  #27
Mauzer's Avatar
Wow, your first post was in a 3 year old thread...Welcome to Yotatech, glad you learned how to use the search button
Old 08-24-2010 | 06:15 AM
  #28
Funrider's Avatar
Old 08-24-2010 | 06:19 AM
  #29
Funrider's Avatar
Old thread but still getting readers! WOW who would have thought !
Old 08-24-2010 | 09:11 AM
  #30
dropzone's Avatar
Fossilized
yes the link you posted is valid however your post has a spam look to it, following their sort of patterns for posting
Numberonedad6
07-30-2015 08:10 PM
terminator
07-27-2015 08:13 PM
Massmayhem247
07-24-2015 01:07 PM
skoti89
07-08-2015 01:05 AM
Vargntucson
07-04-2015 01:15 PM
