Adding the aftermarket Trans cooler
Old 03-23-2010 | 12:15 AM
logsurfer's Avatar
https://www.yotatech.com/forums/f2/e...15/index2.html
Old 03-23-2010 | 07:28 AM
TundraTuff's Avatar
I have the Mishimoto heavy duty trans cooler (the one that comes with a fan and all) mounted right in front of the radiator.
Old 03-23-2010 | 07:35 AM
mt_goat's Avatar
One thing to also consider is the orientation of the cooler. IMHO air pockets can make the cooler less effective, especially those type that have a bypass built in, or that's my theory anyway.
Those were for vertical mounting, but another way would be to mount one horizontal.
Old 03-23-2010 | 10:19 AM
JWaldz's Avatar
goat... I know you wrote the words on the picture but you have the red sharpie in the pic so it looks like you wrote all over your floor and the cooler haha
Old 03-23-2010 | 10:39 AM
  #25
mt_goat's Avatar
Old 03-23-2010 | 05:29 PM
  #26
Kerby J's Avatar
thanx for the posts huys i was jus wonderein bc i didnt know if anybody felt that it was necessary to have a fan mounted on it or if anybody had the before and after with a fan installed and that i was enough of a difference to spend the cash for one
Old 03-24-2010 | 06:11 AM
  #27
mt_goat's Avatar
More air flow the better IMHO, either in front of the radiator fan or add an extra fan just for it.
Old 03-27-2010 | 11:25 AM
  #28
kball's Avatar
Hi all, new member here. I just installed my cooler last weekend along with an inline filter. B & M 70268 cooler and Magnefine filter
Old 03-27-2010 | 12:19 PM
  #29
mt_goat's Avatar
Nice first post, welcome to YT. It would be interesting to dissect one of the used filters when you change it. Looks good.
Old 03-27-2010 | 12:25 PM
  #30
kball's Avatar
Thanks. That's my plan. My trans fluid looked more on the burnt side when I bought the truck so I will change this first filter early (maybe 10K?) and I'll cut it open and post pics.
Old 03-27-2010 | 12:31 PM
  #31
brian2sun's Avatar
Good pics and advice guys!
Old 03-27-2010 | 02:36 PM
  #32
psraff's Avatar
I did mine last year with the TruCool 4454 and an external bypass (I know the 4454 has one built in). Then a few months ago I found codes for my scangauge that will read tranny temps. I haven't had it over 155* yet. So in all honesty, I don't know if my cooler even has been used yet (external bypass opens at 180*). I plan on removing a hose pretty soon to check. Maybe even remove the external bypass altogether...
Anyone remember at what temp the built in bypass opens at?
Old 03-27-2010 | 03:59 PM
  #33
mt_goat's Avatar
Its a passive bypass, so its always open but more goes through when its cold. When its hot the flow dynamics are such that the ATF flows easier around the bypass.
I think you'll find even with an active bypass there is still some flow through. maybe 80/20 or something like that. Just feel the cooler and see if its warm or not.
Old 03-27-2010 | 04:33 PM
  #34
psraff's Avatar
I will check it out, but with that info I'll leave th external bypass intact. That way more stays near the engine to keep it warmer in the cold winter months.
Old 03-27-2010 | 07:17 PM
  #35
ender81's Avatar
Kball- did the B&M come with the mounts and hoses in a kit or did you buys these separately?
Old 03-27-2010 | 07:23 PM
  #36
kball's Avatar
The kit came with 5 foot of hose and the silver brackets you see along with assorted bolts/nuts and some ziptie fasteners. I didn't think that the 5 foot was going to be enough so I bought 8 foot of 3/8 line from Autozone and used about 7 foot of it doing the install. I did not use the line that came with the kit at all. A lot of people feed the new lines through a hole made for the a/c lines but it looked too snug to me so I just went under the frame and back around to the steel lines. I did end up needing a few extra bolts/nuts and washers and since I put in the filter I needed some extra clamps too.
Old 03-27-2010 | 08:57 PM
  #37
Kerby J's Avatar
gotcha how did u figure out which line was the output and the return from the trans
Old 03-27-2010 | 09:02 PM
  #38
kball's Avatar
Lots of threads talk about that. I tested just to be sure. I pulled the lines off and put them in a bucket and started the truck and watched which one the fluid came out of. when you are looking at the front of the truck the line going into the left side (passenger) of the radiator is the "hot" from the trans line. The line coming out of the radiator on the right (driver) side is the return to the trans line.
Old 03-27-2010 | 11:02 PM
  #39
Kerby J's Avatar
alright thanx kball was that what other threads said or did they say it the opposite
Old 03-27-2010 | 11:06 PM
  #40
kball's Avatar
From what I've seen they have it right in the other threads.
