ADD-A-LEAFS Installed
Old 09-16-2004 | 03:12 PM
4Runner1988's Avatar
Finally got around to having the time to install my Add-A-Leafs! Didn't take that long.....and I am very happy with the results.
COST: $35 Shipped to my door from Summit Racing. ProComp Add-A-Leafs
TIME: 4hrs
Here is a pic..... NO MORE SAGGY A**!
The only thing, since I did not replace the entire spring assembly, the right side sits almost a 1/2" lower in the rear. Took me awhile.... ....THe GAS TANK.....When full....the old springs really show themselves.
BEST BANG FOR THE BUCK THOUGH! Untrained eye cant tell!
Old 09-16-2004 | 03:43 PM
seaflea's Avatar
Looks much better I'm sure it feels a lot better too
Old 09-16-2004 | 03:52 PM
nmtoy's Avatar
Looks much better! Did it change the ride much? (stiffer) How long are they?
Old 09-16-2004 | 05:15 PM
dajabr's Avatar
That's perfect. Exactly what I'm looking for. And except for your wheels our truck are identical, down to the roof rack. And my rust. Did you install these alone? I have been on the edge of gettinng the EXP-13120 for a while, though I would prefer something a bit longer to keep the ends fromm folding. How much of the originnal springs sticks out on either side?
Old 09-16-2004 | 06:29 PM
Yes I installed them alone.
The new springs are around 20-21" long. I am not sure how much the factory springs stick out....HURRINCANE WINDS keep me inside tonight! They are located on top of the factory helper spring, or bottom spring. I have not noticed the ends folding....although I see your point. The kit is supplied with new centering bolts. After the u-bolts were reinstalled, I was able to get about two threads showing through the bolts. Enough to hold....but I was suprised how short they really were. I may swap out for longer u-bolts. I dont think safety is an issue...but just peace of mind.
The ride is very marginally stiffer. Lets put it this way....I was hitting the bump stops on some rough highways....now I dont.....I'd say ride is VERY GOOD.
Old 09-16-2004 | 07:15 PM
dajabr's Avatar
This is by far the cheapest alernative, I just wanted to make sure about the length in the long run. I don't plan on beating mine up anyway so it shouldn't cause the dreaded folding.
Old 09-16-2004 | 08:02 PM
4xJedi's Avatar
I've had the exact same set on for close to three years with out a single problem. My u-bolts were also a tad too short but I felt there was not a safety issue. I even put a set on my neighbors Runner. Enjoy!! Nice Runner .
Mike
Old 09-17-2004 | 12:25 PM
dajabr's Avatar
Mike
Cool. Will put these next on the list of mods, maybe do in the spring.
Old 09-19-2004 | 09:05 AM
dajabr's Avatar
Screw it. Bought 'em.
Old 09-19-2004 | 12:10 PM
88-4RUNA's Avatar
im gonna have to purchase a set, my truck is currently sitting like your before pic.
Old 09-21-2004 | 06:38 PM
dajabr's Avatar
Another question...
I just put my bils in today, and it does not appear my u-bolts have enough thread to take another leaf, maybe 1/4 in. before they taper at the ends. Did you replace a leaf or add it?
Old 09-21-2004 | 08:47 PM
4xJedi's Avatar
Originally Posted by dajabr
Another question...
I added. Ater installed and the ubolts torqued, I had about one thread minus visible in the u bolt nut. A hair sub-flush. There should be three or so threads visible outside of the nut but oh well. I didn't have access to new u bolts at the time. After a week I re-torqued the nuts and all has been good ever since. Also the rear will be a little higher than expected for the first couple of weeks. The AAL's will relax to sit level.
Old 09-22-2004 | 03:44 PM
mike_d's Avatar
TIME: 4hrs
i've been thinking about doing this for a while, and your post gave me the extra push to order the AAL. so they came in today, and hopefully i can get them put on this weekend. are there any tricks that you learned that would make it easier for me? the instructions said you need to use a c-clamp to hold the springs when you take the center bolt out. i've never read that on any of the AAL write ups, did you really need the c-clamp?
Old 09-27-2004 | 06:47 PM
Sorry for the delay.....Lost power and headed out on vacation early. Came back to the same crappy Hurrincane weather.
No real tricks to mention. I just followed the instructions.
Awesome.....post some pics when you get yours installed!
nvdesertrunner
05-11-2020 09:18 PM
wwjr
09-07-2015 10:27 AM
punks_is_4x4
08-21-2015 02:35 PM
Esibnitsud
07-30-2015 09:19 PM
