AC idle up
AC idle up
I know I have seen a few post on this but I can't find it.......I know when you turn the ac on the idle is suppose to go up...well mine goes down....cools fine just want idle to go up.....how do you do this? Idle is 700 and when I turn on AC it goes down to 400......Where exactly is the idle up screw.....thanks
It may just need a good tune up.
I don't suggest you ever need to change the idle screw.
If the idle has changed it is for a reason...so look for the reason why and fix it.
The truck idles fine..and it had a tune up...it only drops idle when I turn on AC....I thought there was an "AC" idle up screw for the ac to raise the idle when AC is on...most cars the idle goes up when AC is applied...Please correct me if I am wrong...I just don't think it is normal to idle at 400 when AC is running....idles at 750 when not running.
Blamalam
03-12-2022 07:34 AM
noosh
08-21-2015 03:49 AM
