ABS codes quick question
ABS light is on solid, along with VSC OFF, VSC TRAC, brake! And, speedometer is dead, power windows dead, and shift interlock solenoid is dead. Oh, and Airbag light as well. (This all worked perfectly until I turned it over to my teenage kid, 3 months ago).
So I'm trying to get ABS codes by jumping Tc and E1. I get Cruise Control blinking vigorously, and a couple of Air Bag codes, but the ABS light is still on solid. No blinking codes. My question: Does that mean that there are no ABS codes? Or is something else wrong?
Sounds like bad wheel speed sensor(s), they are used for the speedo as well as TRAC,VSC, but with the other issues perhaps check all fuses for continuity.
Clyby
04-29-2013 07:46 AM
