In about 2 weeks I plan on ordering everything I need to lift my truck,...
Old 11-11-2003 | 09:33 PM
overKILL's Avatar
Im going to have to look up LSPV seeing that I have no idea what that is,... also,... what do you think would be better,... to add a leaf or two,... i dont know how that works,... or just replace the whole leaf spring witha the OME? I saw in a toyo mag the add a leafs,... they sell by the pair and it says 3" lift for like 40 bucks? I guess I would buy one pair and that would lift the rear 3"? I mean if thats the case,... thats alot cheaper,... is it worth it though?
Old 11-11-2003 | 09:46 PM
overKILL's Avatar
Ok,... I read about the LSPV,... basically,... if I lift the rear end and dont adjust the LSPV its going to think that bed of the truck is as light as a feather and the rear brakes probably wont kick in at all,... so in theory,... I have to raise it up by what ever my final lift is,... Gotcha,... does anyone manufacture this braket or whatever so I can just buy it or do I need to make one?
Old 11-12-2003 | 08:22 AM
cruizin01's Avatar
You could go with an add-a-leaf. Its a cheap way of doing it. Your gonna get a real stiff ride and less flex compared with the ome's. I know the ome's are kinda expensive but in my opinion they are worth it. I dont know of anyone that makes that bracket. Its really simple if you can find a peice of metal. Itd be like 5 inches long and and 1 or so wide. Just need to drill a couple of holes and bolt it up. But yeah you would need to raise the LSPV bracket the same amount as the lift you acheived. Ill take a picture of it here in the next couple of days to give you an idea of what you need.
Old 11-12-2003 | 06:24 PM
overKILL's Avatar
Ok, the bracket sounds simple enough to make,... you know I didnt even find out how much the OME leafs are,... Im thinking about 150 like the others,... hmmmm,...
Old 11-12-2003 | 07:12 PM
  #25
cruizin01's Avatar
i think they are about 150 a side..mikes website should have the price.
Old 11-12-2003 | 08:27 PM
  #26
overKILL's Avatar
Ok,... I'll let you know what happens,... I get paid next thursday so that will be the day I order,... keep in touch.
saphirekosmos
06-22-2015 11:26 AM
TheManOutside
06-18-2015 04:32 PM
88Toy
7
06-17-2015 10:40 AM
Old Red 94
06-16-2015 09:32 PM
NerfHerder-97SR5-
06-17-2002 06:31 PM
