A340E pretty much shot. Need some advice.
Old 09-28-2009 | 08:14 AM
jwhalen123's Avatar
The A340F (V6 4x4 Auto think that makes it an A340F) in our 01 Milenium Edition 4Runner was slipping on and off. The other day it gave out on my girlfriend while on the interstate. Since then the transmission will not engage. I pulled the oil pan and noticed a good amount of metal shavings so I cleaned them out, changed the filter, and buttons everything back up hoping for the best. Still no luck. I then pulled the transmission to check the TQ Converter because it sounded like something was spinning/rattling freely at idle in the transmission. But the TQC looked fine. I took the TQC to AAMCO and they seemed to think it was ok and uncommon for a yota TQC to go. I have yet to pull codes but has anybody had this happen to them? I know I probably should just get the tranny rebuild but I definitley don't have the money to do so. Could this be as simple as bad silenoids?
Thx!
Old 09-28-2009 | 09:35 AM
cackalak han's Avatar
Sorry, but rebuild or implosion is immanent.
http://www.ultimateyota.com/index.ph...6&topic=4012.0
Old 09-28-2009 | 10:12 AM
jwhalen123's Avatar
Thx! Great link!
Old 09-28-2009 | 10:38 AM
I have the same transmission. If it goes, I might go with a manual swap.
Old 09-28-2009 | 10:39 AM
StockSucks's Avatar
Solenoids are not gonna make the worn clutches in the trans better. you need an overhaul. You can always try your luck with a used one.
And to answer your other question about E or F. Should say on the side of trans. Either on a tag or on case itself. Not sure the difference but I do know that there were some with a cable, some without. some with 4 solenoids and some with 5. But again IMO your trans is done. Either need a rebuild or a used donor.
Old 09-28-2009 | 10:46 AM
jwhalen123's Avatar
My tranny's model number is 30-40LE I think that is the same as the A340F because I also have 4WD.
Old 09-28-2009 | 11:19 AM
SEAIRESCUE's Avatar
Maybe not.....
I think your pump is failing. Filter and magnets in pan should be catching the metal from the failing pump. Pump is easy change. You may want to have the shop replace the pump and put it back in for a pressure test. Its high risk but equally may put you back on the road. Other options is to get a low mileage unit from salvage yard installed. A rebuilt unit installed is about $3000.
Old 09-28-2009 | 11:27 AM
jwhalen123's Avatar
Hmmm... that's a good idea. The pump just unbolts inside the bell housing right? I have the tranny on the ground so I can pull it to check. I like the sounds of that better.
Can I pull the pump without effecting other internal components?
Old 09-28-2009 | 05:57 PM
jwhalen123's Avatar
So the pump is pressed in so I didn't get to remove it but there is absolutely no shaft play in the pump. Also, my girlfriend added that the shifter itself was at times hard to put in gear and put up resistance going into park and into drive. How common is it that pump goes verses the O/D clutches which seem to be a common failure?
Old 09-29-2009 | 04:42 AM
mt_goat's Avatar
I've never heard of a pump failure with these trannies. But I don't know everything
Old 10-10-2009 | 07:46 PM
Ron Helmuth's Avatar
have a 99 transfer case if needed- not sure if this helps you.
From a 99 SR5 automatic. Likely needs rebuilt itself. Money not really an object... clearing out the garage.
Just trying to be helpful I am a manny tranny guy myself.
pplusent
09-18-2018 11:02 PM
4x4-runner
04-18-2017 10:08 PM
tj884Rdlx
08-28-2015 01:04 PM
upongame619
08-01-2015 01:12 AM
HaydenConQueso
07-12-2015 06:22 PM
