99 toyota 4runner runs rich
help if anyone had this happen to them. My runner starts up great on its first initial startup then through out the day as I turn off and turn on my vehicle it starts to take longer to start up and when im starting the vehicle I can smell raw fuel from the tail pipe. The only way it would start is to press the fuel pedal to the floor and keep it there while I crank on it. When it starts the motor sounds like it's missing, also thick grey smoke comes out the tailpipe and the idle would stay rough for a minute or so.
things i did:
-swap ECM
-r/r idle air
-r/r map
-cleaned throttle body
-poured some expensive inject. cleaner
things i did:
-swap ECM
-r/r idle air
-r/r map
Ok, I've done the cap, plugs and wires, but not the O2. Just to be sure, it's located just before the muffler. Right? Or is there a second one I don't know about?
Thx Yotaman
As far as the fuel regulator, does anyone know how to check it? Or, is it a cheap part you just replace?
Thx Yotaman
JaredL
06-16-2015 05:47 PM
