99 Tacoma 2.7 starts missing as fuel level declines
My tacoma has a misfire/fuel starvation issue when the needle starts to get off of full. it died completely on me when it got to around half.
Previous owner said he had the fuel pump changed (bosch), but didn't give a reason why. Got the truck for $3800 with 180k on the odometer. 2wd.
I don't want to dump a ton of money into it, but here's what I've done so far.
New plugs,wires,pcv,air filter(tune up stuff) changed all fluids, cleaned maf, cleaned IACV, cleaned throttle plate, seafoam, New fuel pressure regulator (idle would speed up when I pinched the return line from the FPV).
Any suggestions?
Any suggestions?
I'm beginning to suspect that something isn't kosher in the fuel tank. I don't know exactly how everything is put together, but it makes sense that it may be a pickup tube issue, or something not seated, bad o-ring type issue.
The problem completely goes away when I fill up.
