'99 AC High side-low side pressures
Old 05-23-2005 | 04:54 PM
gwhayduke's Avatar
Whoooeee it's hot here folks...Over 100F for three or four days now. The AC on the '99 hasn't been all that cool, so I added a can of R134 which brought the low-side pressure to 44 lbs (checked using one of those cheapo AC pressure testers).
Temperature in the vent is 48F. Wondering if the low side pressure is too high now. Gonna run out and get a more accurate Hi-Lo guage set up and recheck.
Just wondering what the high-side, low side pressures are supposed to be.
Old 05-23-2005 | 05:38 PM
MLesch's Avatar
check out http://www.autoacforum.com/ and http://www.aircondition.com/wwwboard/ I don't know much about 134a but 44psi sounds a little high to me.
Old 05-23-2005 | 05:56 PM
DudeBud's Avatar
i thought it was supposed to be around 20-25psi
Old 05-23-2005 | 07:38 PM
gwhayduke's Avatar
According to this pressure-temp chart, at today's temp of 102, the pressure on the low side was within specs of the chart.
Pressure-Temp Chart
Old 05-24-2005 | 06:50 PM
gwhayduke's Avatar
Got the pressures from the AC forum...Great guys, lots of help.
"Pressures list out the same for both vehicles.
Low Side: 21-36 PSI
High Side: 199-228 PSI
Refrigerant Capacity:
1995: 23.2-26.7 ounces of R134a
1999: 21.2-24.7 ounces of R134a
Pressures listed were with an ambient of 86 to 95 degrees."
bigjstang
08-25-2021 01:41 AM
jbv808
08-06-2021 05:47 PM
Doug4320
03-24-2018 11:11 PM
09-04-2015 10:27 AM
