99 4runner stock stereo harness????
ive had a couple different toyotas newer and older but on my moms 99 runner the wiring harness to the stock head unit is different than every other toyota i have delt with.has anyone ever had this problem????? :wtf:
What kind of problem are you having?
I just removed my stock AM/FM/CD unit from my '99. The wiring plugs into a small amp, which then plugs into the head unit.
Depending on what you're doing, if you're replacing the stock unit with an aftermarket unit, you might consider buying a wiring harness from Crutchfield. They come with great instructions and allow you to retain the stock wiring plug so that, should you ever desire to reinstall the stock unit, you can rather easily.
If you need more specific help, provide a few more details. Hope that helps.
i just swaped the stock tereo out of my 99 and put it into my 95. I put a new mp3 player into my 99 and didn't need to buy any harness... all you have to do is bypass the stock amp and hook it straight into your stereo, the wiring harness should be the same, plus those stock amps are typically less powerfull than the built in amps in newer stereos. so the performance well be greater....
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
