Old 04-21-2016, 01:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
98 4runner front wheel bearings
Old 07-11-2013 | 07:22 AM
runnaround's Avatar
Going to be replacing both the front wheel bearings on my 4wd 4runner. I have the bearings only. Will try to keep the snap rings and seals in reusable condition. I want to use a bearing puller and reinstaller to do the job instead of using a press. Good idea or bad?
Old 07-12-2013 | 12:53 AM
wyoming9's Avatar
Red face
I have never used anything but a press.
Not even sure if a puller would work since I don`t have one apart to look at.
seals are cheap!
Old 07-12-2013 | 11:52 AM
Performance1's Avatar
I'd def recommend replacing the seals when doing bearings.... RockAuto sells em pretty cheap (shipping might kill the deal though).
I've been involved with changing front hub bearings several times, in both middle-of-nowhere Nicaragua and back in "civilized" Los Angeles. EVERY time it's always involved a press. You might be able to get them off the hub with a puller.... but for sure you'll need a press to install new ones.
Old 07-15-2013 | 07:53 PM
aowRS's Avatar
How many miles do you have on the 4Runner? I'm at 283,xxx miles (original owner) and am simply amazed that I've never had to replace any of the wheel bearings.
Andreas
Old 07-15-2013 | 07:57 PM
warpigg's Avatar
I would deffinetly do the seals, because if it leaks after you do the bearing and have every thing back together its a pain to go back through it all
Old 09-18-2013 | 02:44 PM
runnaround's Avatar
Hey guys sorry it has been a while.
I did replace the wheel bearings in both front wheels. Took it for a test drive and the noise did was still there. Nothing changed. Also, the wheel bearings looks like they were in good condition. Anyway, I decided to rotate my tires just for the heck of it. Test drove it and the noise is GONE!!!! It's like night and day! The ride is nice and quiet now. Weird how the tires caused the noise at that level and slight vibrations. I felt real bad putting all that time into the truck when it was something as simple as rotating the tires. Oh well it was a good experience.
Old 09-18-2013 | 02:46 PM
runnaround's Avatar
I did all the seals as well.
Old 09-18-2013 | 04:12 PM
chadsy's Avatar
This video may be of interest to you... If I had the money I would just go to harbor freight and get one of their 20 ton hydraulic presses.. Only like 130.
The press would be a lot easier but this video shows you the process:
[YOUTUBE]
[/YOUTUBE]
Old 09-18-2013 | 04:56 PM
runnaround's Avatar
This is the tool I used actually. The job is all done now. thx
Old 09-20-2013 | 11:54 AM
chadsy's Avatar
What kind of noise were you getting? Mine has developed a "whirring" noise when travels and braking at low speeds. I'm thinking it may be a bearing.
Did you get your kit from harbor freight and how much of a pain was the install? Did you have to cut it race to get it to budge?
Old 09-20-2013 | 12:40 PM
mynameistommy510's Avatar
Subscribe
Old 10-10-2013 | 12:34 PM
kevinb's Avatar
When pressing out the bearing and then pressing new one on, what are people using in place of the Toyota SST? I realize a press is needed, but what is used to put the pressure evenly on the bearing?
Anyone in Atlanta area have the rear ABS ring remover and bearing remover tool I've seen on eBay? Or anyone want to make some extra $ if I remove the spindle and you remove/replace the bearing?
TIA,
Kevin
Atlanta
Old 10-10-2013 | 01:45 PM
chadsy's Avatar
TIA,
Kevin
Atlanta
I've heard this works pretty good: http://www.harborfreight.com/fwd-fro...ers-66829.html
06-01-2021 02:51 PM
toyota32
07-06-2015 06:42 PM
Jnkml
07-06-2015 02:20 PM
Vargntucson
07-04-2015 01:15 PM
CJ94yota
07-03-2015 11:14 PM
