98 4runner check engine lightand running rough after cleaning engine bay with water
Old 03-19-2009 | 10:46 PM
joshua fry's Avatar
I was cleaning the engine compartment with a shelf bought engine degreaser on a warm engine not idling. I washed off the grit with a water hose and later that evening drove it and noticed a rough idle and then my check engine light came on. Did i get something wet i wasn't spose to? Thanks josh
Old 03-19-2009 | 10:51 PM
DeathCougar's Avatar
Check in your spark plug tubes. This is very common. You likely have water in one or more tube, causing a misfire in each cylinder.
I have "repaired" a number of peoples rigs because of this problem.
Old 03-19-2009 | 10:57 PM
joshua fry's Avatar
ON THE PASSENGER SIDE, WOULD IT BE POSSIBLE FOR THE WATER TO GET BY THE COIL PACKS AND INTO THE TUBES? I PULLED 2 OUT ON THE DRIVER SIDE B/C THEY WERE EASY TO GET TO AND THEY LOOKED GOOD. i GUESS I NEED TO PULL THEM ALL HUH?
Old 03-19-2009 | 11:01 PM
Yes, its very easy for water to get in there.
Pull them all out (after you learn to stop typing IN ALL CAPS) and look for water in there. I bet you find at least one tube with water in it. If you do, dry it out best you can with a paper towel, then pull the plugs (all) and turn the engine over to blow it all out. Let air dry a while, then put it back together and it should be running good again.
Old 03-19-2009 | 11:17 PM
joshua fry's Avatar
O.K. thanks for the advice and the detailed info! I'll get right on it in the morning.
Old 03-19-2009 | 11:42 PM
Elton's Avatar
reason i disconnect the battery cover the up the alternator and then after i clean it take a leaf blower or air hose to it
Old 03-20-2009 | 04:10 AM
GSGALLANT's Avatar
If you get your codes read, it will tell you which cylinder is mis-firing, which will tell you which plug has water around it, but it's a good idea to check all the sparkplugs anyways. Keep in mind that you're not necessarily looking for a sparkplug that's fully submerged in water. Even a tiny bit of water around the plug base (1/8") can cause a misfire. I wouldn't bother removing the plugs... I would just remove the plug wire, stuff paper towels down around the plug to get most of the water out, then use compressed air from a nozzle or wand to blow the rest of the water from around the plug base.
Then, get your codes erased and take it for a test drive.
Old 03-20-2009 | 08:29 AM
joshua fry's Avatar
How do I reset the codes? I've read on here elsewhere that you just undo your battery and the computer will reset itself. Is this true?
Old 03-20-2009 | 08:34 PM
joshua fry's Avatar
I checked all the sparkplug tubes and wound up with one having about 1/8" of water in it. Used a towel and a screw driver to dry up what i could and pulled the plug and dried it off. Let air dry for a while and then reinstalled. Unhooked the battery cable to reset the computer and it cranked right up and drove like a brand new one. Thanks for all your help. You guys really save alot of people there money and heartache.
Old 03-20-2009 | 09:47 PM
Glad to help
Old 05-16-2009 | 09:24 PM
mrloyd's Avatar
thats weird. I just bought anothe runner and did the same dumb thing. For some reason I thought this couldn't happen with the individual coil packs and distributorless ignition. Shows what I know...
Ichneumon
09-27-2015 05:21 PM
Alex Bessinger
06-28-2015 11:05 AM
shadowbirdie
06-24-2015 04:54 PM
95Runner
06-09-2002 10:08 AM
