'97 max load
'97 max load
I wanna put a pop-up camper on my '97 Tacoma with stock suspension and supersprings.
The Palamina Bronco Camper is about 1100 lbs. Is this too heavy for my older Tacoma?
Thanx
Thanx
:jessica: Just How often and how far do you plan to travel??
If this is a once and done thing maybe but for constant use I don`t think I would want to do it.
That 1100 pound weight is minus all the extra goodies you need to camp which will add weight real quick.:jessica:
Well its not, not fine. wyoming9 has a good point, thats the camper weight then your goinna add gear, water, and such. But its still doable if done right. Check out this guy's setup its pretty nice.
https://www.yotatech.com/forums/f83/...rofile-121217/
Air bags arent that much. Actually the cost of a nice tent is pretty comparable to an air bags setup for a taco.
These trucks are pretty capable.
3500lbs loaded
3500lbs loaded
smilen724
13
11-08-2015 05:11 PM
sonorn67
09-19-2015 06:39 PM
