97 4cyl into a 95??
97 4cyl into a 95??
I have a 95 tacoma with a blown headgasket... and an opportunity to buy a running 97 4runner with a bad rear for cheap. Can I drop the 97 engine into the 95? What if anything do I need to change?
Need to know if I should buy the runner asap
Thanks so much
Thanks so much
Yes you can do the swap but it will be like any other swap .
I don`t know enough about the newer engine
Exhaust and intake on the same side as the 95??
Perhaps mating the drive line could be fun.
The wiring is a given the merging of the two wiring harnesses.
The fact your asking leads me to think perhaps more work then you want to get into
He's talking about two of the same generation trucks with the same engine. This isn't a swap, it's a replacement.
OP, I believe the 4runner has different plugs for intake manifolds, sensors, and misc things. Worst case, you might have to swap all your accessories off of your engine onto the 4Runners long block.
Shouldn't be a huge issue.
Does the 97 4Runner have a distributor like your tacoma?
I am not sure yet, on the distributor i will be seeing the truck today. If the 4runner engine does not have a distributor what will that mean? does the block still have a place for one?
thanks so much for the reply
X2 Swap the rear, then rebuild your Tacoma engine and get a TRD rear out of another Taco and swap it in, then you got 2 great Yotas.
ok you guys are assuming alot.... for example, that the 4runner is NOT a POS which it is.
i just need info on swapping a 97 2.7 to a 95.5 truck
thanks dudes
thanks dudes
yeah this is what i am trying to get to the bottom of.... if the physical engine is the same.. though should be able to swap whatever to make it work ya?
since i have the whole truck.... could i swap the engine harness and ecu and run the 4runner engine? is this a stupid amount of work?
The biggest thread in the world is over on marlin crawlers forum. They do 22r to 3rz swaps and there are a bunch of them. You will need new engine mounts but the 3rz will bolt up to the w56 with a w58 bellhousing. The wiring is not impossible but will take time and there are several companies who will do it for around 500 bones. I read a lot about it but I don't have the cash to acquire everything. Good luck in your project.
Beamed from my dumb phone using Yotatech
looking to swap a 97 coil pack type 3rzfe to a truck that has a 95.5 distributor type 3rzfe
Did I mention I am dyslexic?? Lol sorry man.
I do believe the ecu would be involved but I don't think it would be quite the nightmare described.
I have owned both a 99 Tacoma and I currently have a 98 4runner and while I wouldn't quote me I haven't noticed any differences between the two engines.
I think it is doable but you will need the 4runner ecu as the signal from the coils comes from the ecu.
I wouldn't imagine that the areas where the engine harness meets the body harness would be any different as it wouldn't make sense to make two different engine/body harnesses. The only differences would probably be found in the difference in years.
Again sorry about the mixup.
